f**k Buttons Vocal Sample
Re: f**k Buttons Vocal Sample
Use your hand to cover and uncover the speaker.
- tallowwaters
- Gear: LC-MS/MS
Press your knuckles into your throat and j**k up and down quickly.
- rharris07
- Expert Member
- Real name: Ryan
- Band: Ghost Fires, The Witch Family
i have to say - neither one of those ideas sounds right at all.
i think i'll try running it through my microkorg, and possibly the sl-20 pedal. then perhaps i'll look into violently attacking my throat or covering speakers.
MEK | SixTrak | DrumTraks | Motif 8 | DW8000 | MicroKorg | EMX1 & ESX1 | Soviet TOM | Arp Quartet | SD-1 32V | Elka 490 | Indigo 2 | E6400 | Morpheus | SQ2 | DotCom Modular
- speak_onion
- Real name: Dan
- Gear: Octatrack, G2 Engine
- Band: Speak Onion
Never used and ESX, but on th ES-1, the "chop" or whatever feature it is does the thing where it cuts a sample up into 16 (or however many you specify) pieces, and you can turn each piece on/off with the sequencer buttons. Turn off every other one (or different patterns if you want to get saucy with it) and boom, you're there.tallowwaters wrote:Well on the ESX, you can set the samples Amplitude/Pan/Cutoff Frequency/Pitch to be controlled by a clocked sample and hold LFO. Couple that with a motion sequence and you have some pretty out there gating sounds.
THE WORLD REALLY NEEDS MORE RHYTHMICALLY GATED VOX
