Hey team. Some questions for those of you both on the bleeding edge and trapped in the stone age.
I've FINALLY gotten my hands on an external USB floppy drive, to manage disks for my Akai CD3000xl and Roland S-550. I looked about for info reguarding mac OSX, and it looks like that's out. So I fired up my new Windows 7 laptop, downloaded some of the ancient floppy disk utilities, and I'm discovering that many of them will not run or install under Windows 7. Boo.
As I understand, Windows 7 does not have DOS- that thing most of these little utilities need at a critical level. Does anyone know of a way to get these guys going? I'd really love to have Akaidisk and similar working.
thanks!
Old floppy sampler utilities and Windows 7
- Silverfish
- Real name: Tyler
- Band: Silverfish
- madtheory
- Real name: Tomas Mulcahy
Re: Old floppy sampler utilities and Windows 7
Why not keep an older Win XP machine around for the samplers? Also, SCSI is useable on the Akai.
- Silverfish
- Real name: Tyler
- Band: Silverfish
Actually, I remembered I have an old xp laptop sitting around. I fired it up and it seems to be working much better for this application. I'll have to see if I can find a machine with a SCSI card.
Thanks for your help!
- Real name: Unpronounceable
Or get a USB-> SCSI adapter- Castlewood used to make them for the ORB, and then after Iomega sued them out of existence and bought the carcass, they made the same ones for the "USB Jaz drives" (which were just SCSI JAz drives with a USB to SCSI adapter copied from the Castlewood design- in fact the early ones are recognized by XP as the Castlewood hardware)
- hollandturbine
I keep an old Windows 98 PC handy for such things, but if I had to I would just boot the computer with DOS from the USB floppy drive or if possible (depends on hardware backwards compatibility) set up a dual boot system with Windows 98.
