USB-Drives and SCSI?
sepiakeys
Gear: Hardware Synthesizers and Guitar Effects
Band: There will be Lions
Post by sepiakeys » Thu Nov 18, 2010 1:05 pm
Hello!
I got myself an E-MU E4XT Ultra and would like to load EOS-Banks I have converted out of my Emulator X3 into the sampler. I have an SCSI-CD-Rom, but it won't read CDRW's!
Ist there something like a USB to SCSI-adapter, so I can import my banks directly from a memorystick? Or would it make sense to get a SCSI-PCI-Card to transfer data from the PC to the E4XT?
Thanks!
Good programming is worth more than the most expensive synthesizer.
speak_onion
Real name: Dan
Gear: Octatrack, G2 Engine
Band: Speak Onion
Re: USB-Drives and SCSI?
Post by speak_onion » Thu Nov 18, 2010 5:27 pm
You could get a USB zip drive and a SCSI zip drive and transfer back and forth between the 2.
You could get a SCSI CF card reader and a USB card reader and transfer back and forth between the 2 (this is what I am doing for my E4 Platinum I just got).
Look at scsiforsamplers.com
b3groover
Real name: Jim
Band: THEO
Post by b3groover » Thu Nov 18, 2010 6:00 pm
The USB protocol utilizes a computer's CPU, which means it needs drivers. Therefor, you cannot use USB with a piece of gear that's not designed for it unless you can modify the OS. In other words, you can't use a USB to SCSI adapter on a synth.
speak_onion's post contains your best options.
Real name: Unpronounceable
Band: Eridani V
Post by Ashe37 » Fri Nov 19, 2010 6:15 am
USB to SCSI adaptors like the old Castlewood unit ( and the castlewoods rebadged as Iomega) are reported to work for SMDI and file transfers for E4 samplers, but this is from a computer to the sampler. There's really no way to attach a usb device directly to the sampler.
speak_onion
Real name: Dan
Band: Speak Onion
Post by speak_onion » Fri Nov 19, 2010 4:56 pm
I installed my SCSIforsamplers CF card reader in my E4 last night and I was blasting samples back and forth in no time. Highly recommended.
