Old Roland Samplers (S Series, W-30, etc)
anarose
Re: Old Roland Samplers (S Series, W-30, etc)
Post by anarose » Tue Nov 27, 2012 10:29 pm
Hi everybody !
I'm just one question : is it possible to replace The HD of S770 by a CF Reader ?
Because this is a special SCSI ( 40 pins )
Thanks
anarose
Post by anarose » Sat Jan 05, 2013 2:24 pm
nobody use a scsi CF reader for a S770 ?
iphoenix
Real name: Paul
Post by iphoenix » Sat Mar 28, 2015 6:24 am
cornutt wrote:
thared33 wrote:
V301H wrote:
The S770/750/760 can all convert load S550 files.
But is that only for the old S550 CD-ROMs, or can the S760 actually convert load the S550/W30 floppy disks?
Pretty sure the 760 can do that... the 750 manual explicitly says it can, although I've never tried it.
Apparently the S760 can not load S50/550/330/W30 samples on floppy disc. The S770/750 can however.
The S760 can only load S50/550/330/W30 samples via SCSI CD ROMs .
I have a large collection of mostly my own samples, riffs,drones etc of old synths that I have sold on W30 floppy discs, but my W30 stopped working a few years ago unfortunately. I just bought an S760 , (hasn't arrived yet) but I was disappointed to learn that I won't be able to load my W30 floppies ,upon downloading & studying the manual.
max badwan
Real name: Max
Post by max badwan » Sat Mar 28, 2015 6:38 am
I converted my S550 library to S 760 via FDD, no problems.
synthparts
Post by synthparts » Sat Mar 28, 2015 9:19 am
I have a prototype MKS-200 sampler. It wasn't ever released but is basically what became the S-220. You can see it in the upper right of this pic above the MKS-100 -
Chewy
Gear: Alpha Juno 2, Bass Station 2, CZ-5000, DW-8000, DR-660, EA1 mk2, ES1 mk2, JP-8000, Monotribe, R-100, SH-32,
Band: Soundtrack to Psychosis
Post by Chewy » Sat Mar 28, 2015 6:09 pm
^That's awesome!
Great MKS collection overall, too
iphoenix
Real name: Paul
Post by iphoenix » Sun Mar 29, 2015 5:11 am
max badwan wrote:I converted my S550 library to S 760 via FDD, no problems.
Max, that is awesome . The manual indicated clearly that it was not possible. (If Roland early manuals ever indicate anything clearly.)
I don't have nor have I ever used an S760, but I am getting one next week.
If that is the case Im really pleased. Maybe an OS upgrade enabled that? Thanks for clarifying that.
However below quoted from the
S760 Manual: "
Disc Mode.
CONVERT LOAD.
A CD ROM disc for the S550/W30 can be read into ( convert loaded ) the S760 & then used.
* IT IS NOT POSSIBLE TO CONVERT LOAD FLOPPY DISC DATA.
Advanced 3-88 "
max badwan
Real name: Max
Post by max badwan » Mon Mar 30, 2015 7:53 am
If that is the case Im really pleased. Maybe an OS upgrade enabled that? I'm running OS 2.3 if that helps. Thanks for clarifying that.
synthroom
Real name: Kirk
Post by synthroom » Mon Mar 30, 2015 3:39 pm
S760 Manual: "
Disc Mode.
CONVERT LOAD.
Advanced 3-88 "
You just need to have the right Manual...
There is a S-760 Version 2 OS. In its manual, it says it CAN do Convert Load from S-550/W-30 floppies. It also says the Ver. 1 OS was only able to do this from external SCSI devices like CD-ROMs.
synthroom
Real name: Kirk
Post by synthroom » Mon Mar 30, 2015 3:45 pm
So there's a version 2.3 of the S-760 OS? I've only ever had the Version 2.24. Any suggestions on where to get the Version 2.3?
max badwan
Real name: Max
Post by max badwan » Mon Mar 30, 2015 8:01 pm
synthroom wrote:So there's a version 2.3 of the S-760 OS? I've only ever had the Version 2.24. Any suggestions on where to get the Version 2.3?
My bad, OS 2.23. I was having a seniors moment.
synthroom
Real name: Kirk
Post by synthroom » Mon Mar 30, 2015 9:11 pm
OK - thanks. I've been looking all over the interwebs trying to locate a newer OS...
synthroom
Real name: Kirk
Post by synthroom » Mon Mar 30, 2015 9:15 pm
My question is does anyone have a functioning Roland CD-5 unit? I've bought 2 of them and both the load/eject mechanism on them are non-functional. I've tried taking them apart to see what's up - on the first one the rubber bushings on the mechanism had fallen apart and the second one seems to be heading that way.
Has anyone found any other CD-ROMs that work with the S-550?
iphoenix
Real name: Paul
Post by iphoenix » Tue Mar 31, 2015 4:10 am
Thanks Max & Synthroom, for the information on OS 2x for the S760 etc
Im delighted to know that I will be hopefully up & running immediately with my incoming S760 with my S50/W30 samples on floppies. Hoping the OS is the latest.
Hope you find the Roland CD drive Synthroom,
max badwan
Real name: Max
Post by max badwan » Wed Apr 01, 2015 5:58 am
iphoenix wrote:Thanks Max & Synthroom, for the information on OS 2x for the S760 etc
No problem. You can get OS 2.24 on eBay if all else fails.
synthroom wrote:Has anyone found any other CD-ROMs that work with the S-550?
I use a generic 1/2 tower HDD/CD SCSI combo, I think the CD drive is Panasonic. The old Apple drives work as well.
