Trigger Out from MPC 1000
Postby haydenvan » Tue Mar 20, 2012 6:26 pm
What is the best way to get a programmable trigger out for analog gear (Roland sequencers, arpeggiators, etc) from one of the assignable outs on the MPC 1000? I tried blowing up samples such as rim shot or clicks but it was off timing.
haydenvan
Gear: Roland SH-101, CSQ-600, Korg KR-55, Ensoniq SQ80, Akai MPC1000
Re: Trigger Out from MPC 1000
Postby Sir Nose » Wed Mar 21, 2012 2:20 am
Are you triggering a gate/envelope or a clock?
Funkadelic wrote:nothing is good unless you play with it
all that is good is nasty
Sir Nose
Real name: Bob
Postby haydenvan » Wed Mar 21, 2012 2:25 am
I guess a gate or click in. It would be 16th note 8th note or some sort of rhythm not 24ppqn or anything if that's what you're asking.
haydenvan
Postby Stab Frenzy » Wed Mar 21, 2012 4:01 am
You just want a pulse that's at 0dBFS or thereabouts. You don't want an audio signal as that will have multiple potential trigger points, although they can sometimes work.
Easiest way to do it is to get a synth with a square wave, record the lowest sound you can get from it with a single oscillator into your MPC with the filter wide open and the volume all the way up, go into the sample edit mode and chop it so it's just a single cycle of the positive pulse and use that as your sync sample. That's what I did with my 2500 and it worked great.
If you've got a synth that goes really low you might not end up with a nice square edge on the waveform, if so sample a higher note and pitch it down if it's to short to work properly.
Postby Sir Nose » Sat Mar 24, 2012 9:36 pm
For a clock you can also try a constant tone (experiment with pitch, I'd go mid to high) with the amplitude modulated from silence to max with a square wave. Adjust the LFO rate to speed up or slow down the clock. Use PWM for freaky effect. Not sure if you could do that on an MPC.
Sir Nose
Real name: Bob
Postby haydenvan » Tue Mar 27, 2012 11:51 pm
I got it to work with Stab Frenzy's method. But will sending this audio trigger out from one of the individual outs in the MPC be damaging to any analog gate/trigger/step/etc inputs?
haydenvan
Postby Stab Frenzy » Tue Mar 27, 2012 11:57 pm
haydenvan wrote:I got it to work with Stab Frenzy's method. But will sending this audio trigger out from one of the individual outs in the MPC be damaging to any analog gate/trigger/step/etc inputs?
No, it's all just voltage.
Postby Sexor » Sun Apr 15, 2012 1:43 pm
Stab Frenzy wrote:You just want a pulse that's at 0dBFS or thereabouts. You don't want an audio signal as that will have multiple potential trigger points, although they can sometimes work.
I've done exactly this with my MPC1000 to trigger various things, such as SH-101, ProOne, MS20 etc. Works like a charm.
Using the multiple outs, I've built and sequenced entire live analog drumkits like this.
Monkey business since 2007!
Sexor
Gear: Prophet6, Jupiter-7, MS25, Juno-50, TR-303, Rhodes 63
Postby haydenvan » Sun Apr 15, 2012 4:31 pm
I just wish there were more outs on the MPC!
haydenvan
Postby Stab Frenzy » Mon Apr 16, 2012 12:09 am
Get a 2500 then.
Postby Nannerfan » Mon May 07, 2012 6:12 am
Just use the tape808trigger sample from Goldbaby.
Can't remember but I think it's included in one of their free kits.
Nannerfan
Gear: Akai AX-60, AX-80, S612
Arturia Microbrute
Roland D-550, TR-8
Yamaha QY700, SU700, TX81Z
Postby drewtoothpaste » Tue May 08, 2012 12:34 am
Here's a WAV file I use on my 2500 to trigger analog gear:
http://crudbump.com/pulse-2db.WAV
The Worst Things For Sale, a blog about horrible stuff for sale online * Stuff I Put On Myself: a makeup blog
drewtoothpaste
Real name: drew
Band: CRUDBUMP
Return to Samplers
