Left channel on my Ensoniq EPS is louder then the right.
Postby suchenderxxx » Tue May 08, 2012 7:49 pm
Hello board members,
i have a problem with my EPS the left channel (which is a channel where you can plug your headphones or the left output) is 3 db louder then the right channel of my EPS. Maybe the right is lower....
If i dont plug the cable from the left channel till the end the volume goes down 1,5 db... and then the difference is only 1,5 db between the left and the right channel...
i opened the eps and looked if i can find something wrong but to me it seems everything is fine. Do any1 from you know if there is a way to open the plastic case around the outputs from the eps? I thought that it could be a connection problem... Or has any1 from you an idea what this problem could be?
thanks Tarkan
suchenderxxx
Re: Left channel on my Ensoniq EPS is louder then the right.
Postby Ashe37 » Tue May 08, 2012 8:06 pm
Did you try cleaning the outputs?
Did it really save you that much time to not type "anyone"?
Real name: Unpronounceable
Band: Eridani V
Postby suchenderxxx » Tue May 08, 2012 8:15 pm
how do i clean it is there any special way doing this?
try it it saves much time if you calculate that you type this word every week. then its 52 times in a year... ;)
suchenderxxx
Postby Ashe37 » Tue May 08, 2012 8:22 pm
Contact cleaner and a q-tip.
Band: Eridani V
Postby meatballfulton » Tue May 08, 2012 8:23 pm
I think that is a "feature" of all Ensoniq boards of that vintage with the L/phones jack.
Postby suchenderxxx » Tue May 08, 2012 8:38 pm
i know a guy who owns also an eps, we are email buddys. He does not have this problem... but im not the only one, cause i found posts in the internet, where other guys have the same problem...
suchenderxxx
Postby suchenderxxx » Tue May 08, 2012 8:41 pm
Maybe im using wrong cables? i use the Cordial CFU 1,5 PP???
suchenderxxx
Return to Samplers
