mpc200XL question
mpc200XL question
Postby sam » Sun Nov 18, 2012 4:01 pm
I thought it best to ask in this section...How do you assign the pads to trigger say a korg ER-1...or any midi synth..?
Lam memorymoog.Sonic six.Vp330 mk1.SH101.OSCar.ARP odyssey..multivox mx3000.Solina stringsynth.polivox
ms20/50.Andromeda. OBX.
Prophet 5 Pro-one. Wasp.EMS AKS.
sam
Re: mpc200XL question
Postby plus321 » Sun Nov 18, 2012 6:24 pm
On my mpc3000, I set the track to the midi channel I want to control and leave it as Drum. You'll have to make sure your pads are set to the midi note numbers you want. I set mine to ascending so c1 is the first pad and c#1 is 2, etc, but sometimes they are set differently.
plus321
Postby nogginj » Fri Dec 14, 2012 5:58 pm
the above is correct but you could also switch the program type from DRUM to MIDI - which is handy if you are not triggering internal sounds with the same program.
the default pad numbering system will kill you though - its all over the place.
i have a blank program with the correct midi note numbers (created via an auto-chromatic pgm) that I use as a template to play chromatically with.
nogginj
Return to Samplers
