Emulator II - Sampling Noisefloor
Re: Emulator II - Sampling Noisefloor
Postby madtheory » Fri Mar 29, 2013 12:33 pm
That makes no sense. Are you sure he didn't say a Dolby A decoder? Common trick for adding top end, but it doesn't remove noise.
And it's not a filter. dbx works on the dynamic range, not frequency. dbx works by companding, it's not single ended. And the EII already has a companding DAC on the input, and a method of digital compansion for the sampling. What that engineer describes would not work because the audio has to be encoded by dbx first, and even if he did do that it would cause more problems than it solves because the EII is already companding twice.
Band: madtheory
Postby HideawayStudio » Fri Mar 29, 2013 8:19 pm
The EII is no more noisy than anything else from the era - it has a wonderful sound.
HideawayStudio
Real name: Dan Wilson
Band: Shortwave
Postby Erotic Cabaret » Sat Mar 30, 2013 12:22 am
Well, it does have a wonderful sound, but I think the key is not using the on-board sample input and, instead, getting all your samples through the COMPUTER INTERFACE on the back. It's a bit of a work-around, though. I'll go with a V-Synth version 2 for now...
"The Jupiter-4 will be tatooed on my heart for ever."
--Phil Oakey
Erotic Cabaret
Real name: Tyler
Gear: Pro One, SQ-80, EII+HD, NL3, MoPho
Postby JMP » Sat Mar 30, 2013 12:31 am
Every single one of my custom soundbanks has been sampled via the 1/4" jack input from a headphone socket on my PC soundcard interface. Nothing flash there and I've never had any complaints... Tried to sample my old Jupiter 8 into a V Synth Ver 2 and it mangled then all over. :D I didn't find it an easier option.
I'm no tech and can't explain why but sampling some stuff into the EII actually made it sound better to my ears, far punchier at the bottom end for a start. Again, no noticable noise so maybe it's your EII.
JMP
Postby Erotic Cabaret » Sat Mar 30, 2013 3:15 am
I think it must be my EII, John. I tried emailing you about this a while ago I think, haha...
You don't do your sampling through the analog input, though...you do it through the computer interface, don't you? I never got my Mac Classic CD drive to work...
--Phil Oakey
Erotic Cabaret
Real name: Tyler
Postby JMP » Sat Mar 30, 2013 9:23 am
Ah right, I'm no good on the tech side sorry. No, all my sampling is through the 1/4" sample input jack. I use the computer interface with Mac & Sound Designer (loading and unloading soundbanks only) but no sampling through it.
JMP
Postby Stab Frenzy » Sat Mar 30, 2013 10:14 am
Is there anyone who actually listened to the example file EC posted and believes it's unacceptably noisy? I think the issue is in the mind of the user rather than the sampler.
Postby madtheory » Sat Mar 30, 2013 11:10 am
Stab Frenzy wrote:Is there anyone who actually listened to the example file EC posted and believes it's unacceptably noisy? I think the issue is in the mind of the user rather than the sampler.
Agreed. The example posted had only a tiny amount of noise compared to source.
Band: madtheory
Postby JMP » Sat Mar 30, 2013 11:31 am
Glad I'm not the only one that thought that...
JMP
Postby tekkentool » Sat Mar 30, 2013 12:39 pm
+adding noise is good as sometimes. I don't remember a track in recent memory where I've had a saw bass without a little bit of noise mixed in...it's arguably a big load of what makes people think old samplers are so "punchy"
tekkentool
Real name: Steve
Band: none currently
Postby madtheory » Sat Mar 30, 2013 3:43 pm
Yes, and it really doesn't help one's creative output to be overly concerned with a little bit of noise. Or distortion of any kind. Just enjoy the EII for what it is- a well designed musical instrument comprising a bunch of pros and cons that might lead you in a certain direction if you view them as boundaries rather than limitations. If it doesn't float your boat try a different tool.
Band: madtheory
Postby Erotic Cabaret » Sat Mar 30, 2013 4:32 pm
I'm going over to synthroom's this morning. (Dunno if you guys know him, but he's on this forum and also lives in PDX.) Anyhoo, we're going to compare noisefloors on our EIIs and I'll let you know what we find.
--Phil Oakey
Erotic Cabaret
Real name: Tyler
Postby synthroom » Sat Mar 30, 2013 8:43 pm
Tyler brought his EII over and we compared it to my EII, and his definitely is noisier than mine.
Here's a screen shot of my mixer with both our EIIs connected using just 1/4" patch cables directly into my Presonus Firestudio project interface.
There's definitely a differnce in the floor noise. We tried the reseating trick on all the chips that were readily reachable but that had no effect.
Kirk
synthroom
Real name: Kirk
Postby Erotic Cabaret » Sun Mar 31, 2013 12:24 am
BUMP!
--Phil Oakey
Erotic Cabaret
Real name: Tyler
Postby Stab Frenzy » Sun Mar 31, 2013 6:44 am
synthroom wrote:Tyler brought his EII over and we compared it to my EII, and his definitely is noisier than mine.
Kirk
I thought the noise was only added to the sample after it had been sampled? Originally EC said that the sampling process was adding noise to the samples that weren't there when the sample was originally played, the level of noise when nothing is playing has no relationship to that at all.
Also those figures tell you nothing without knowing what level a sample is playing at, it's SNR that's important, a ratio rather than an absolute value. Lastly if you had set everything up correctly for the test a noise floor of almost -60dB is actually very good for an 8-bit sampler.
PreviousNext
Return to Samplers
