Complete Beginner - What Do I Need?!
Postby Jack_Tatty » Sat Apr 13, 2013 11:38 am
Hi there...
I'm trying to teach myself electronic music...
Now that I live out in the countryside, it's not so easy to hook up with a bunch of people in a rehearsal room so's to make noise... So, I want to look into what I need to do to go solo, as it were...
I've an idea that a sampler would be useful - but I'm not sure. I want something to help me play live, and I want something to help me get around the fact that I can't play keys with more than two fingers. With a sampler, would I be able to record a selection of different chords / sequences of chords and assign them to a single pad on a sampler? Could a sampler play the whole rhythm section of a song while I play lead lines on another instrument?
So far, all I've got access to is GarageBand (I've a keyboard controller, too), a bass guitar and a MicroKorg...
Sorry! Lots of vague questions!
Any suggestions / ideas appreciated!
Keith.
Jack_Tatty
Re: Complete Beginner - What Do I Need?!
Postby Z » Sat Apr 13, 2013 1:54 pm
I don't think you would want a sampler to play back chords. If you same a chord (ie, a major chord), it will be that chord on every key you play. For every key signature you chose to write or play a song with, there are a limited number of major chords that can be played in that key. For instace, if you chose C as your key sig, you can only play the follwoing major chords: C (C, E & G), F (F, A & C) and G (G, B, and D). If you played a sampled major chord on D, it would not fit the key since D major's notes are D, F# and A - F# is not in the C scale.
Sounds like you need something with a sequencer. A sequencer is like a word processor for music. You record note information either in real-time or step-time and manipulate that musical data as you see fit. You can record one passage, rewind to the beginning (or any other place) and overdub another passage. A common way to build up a song is to fisrt record a kick and snare pattern, next overdub your hi-hat pattern. Then you can lay down a bass line and then some chords. If you have difficulty playing more than 2 notes at a time, just record those 2 notes of a chord first and overdub the other notes.
Workstation keyboards integrate a synthesizer and/or sampler with a sequencer. You have not stated a budget, but the Roland Fantom X6 is a great workstation that can be picked up used for under $1K.
Z
Postby GuyaGuy » Sun Apr 14, 2013 5:05 pm
Sounds like you just want pre-recorded backing tracks. Garage Band would do that just fine.
GuyaGuy
Gear: YES PLEASE!
Postby madmarkmagee » Mon Apr 15, 2013 8:54 am
Some synths have something called chord memory. Think alpha Juno has it.... But really you better off just practicing your keyboard skills...
madmarkmagee
Gear: King Korg
ESQ-1
Reface DX
Microbrute
Shruthi-1
Pittsburgh System-1
Juno 106 (needs work)
Postby madmarkmagee » Mon Apr 15, 2013 9:00 am
Watch on youtube.com
May be of use...
madmarkmagee
Gear: King Korg
ESQ-1
Reface DX
Microbrute
Shruthi-1
Pittsburgh System-1
Postby Z » Mon Apr 15, 2013 1:00 pm
Just like a sampled chord, Chord Memory on a keyboard will play the same chord on every key.
Z
Postby ninja6485 » Mon Apr 15, 2013 9:54 pm
You could still just record individually played chords and trigger the different recordings when you want to play a different chord. If you got something with 16 pads, you could record 4 variations of a looped segment, and then do that for 4 instruments and put jams together that way: Verse, chorus, bridge, solo/ fill. Or record a song into garage band and play along to it.
ninja6485
Return to Samplers
