SP-1200 Phasing/Flanging
Postby Rumbler101 » Wed Apr 16, 2014 1:32 am
Is it possible to do this with an SP-1200 or would you need an external effects processor? If it's possible, how would it work?
Thanks.
Rumbler101
Re: SP-1200 Phasing/Flanging
Postby Sir Ruff » Wed Apr 16, 2014 3:17 am
Pretty sure it won't work--the step resolution is too low to get samples close enough to allow for flanging. Although I've never tried this using the high-res mode. And even then, you'd have to do it from multiple sample slots, as each channel is monophonic (meaning a new sample will always cut off the old one from the same channel). Better to just get a cheap external unit.
Do you even post on vse bro?
Sir Ruff
Band: Ruff in the jungle
Return to Samplers
Users browsing this forum: No registered users and 7 guests
