The most over-used terms used to describe sound
- Swayze
- Junior Member
- Gear: Mono/Poly, Pro-One, Juno-60, JX-3P, AX80, SQ80, AN1x, DX100, DX7E!, DX7IIFDE!, TG77, EX8000, Microbrute, Behringer D, Drumtraks, TR-08 and Eurorack
Re: The most over-used terms used to describe sound
Spacey, Bassy, Tinny, Sharp, Harsh, Brittle, Smooth, Dark, Bubbly, Juicy and Metallic.
for sampler:
the 12-bit grit
the 12-bit grit
- Sir Ruff
- Gear: Two persimmon modulators and a frequency adjudicator.
- Band: Ruff in the jungle
totally... all 12-bit samplers do NOT sound the same.JVC wrote:for sampler:
the 12-bit grit
Do you even post on vse bro?
- moodorf
- Junior Member
- Gear: Little Phatty (needs repair)
Blofeld
DSI Prophet 08
Ensoniq SQ80
Pittsburgh Modular System 10
Renoise
FL - Location: Western NY
"Digital"
Usually used pejoratively.
- CS_TBL
- Gear: All "In-The-Box"
Mainly FM8 - Location: NL
MIDI
If some client o' yours (who knows a bit about music production) tells you your music sounds MIDI, then he means it sounds c**p and dated.
FM8 vids
FM8 vids
- synthroom
- Senior Member
- Real name: Kirk
- Gear: Fairlight IIx(!), JP-8, D-50, S-50+550, S-760, JX-3P, JD-800, EII, Emax II, Mini, ARP 2600, P-5 Rev.1, Pro-One, Performer, K1m, K5m, few other things.
if you want grit, try 8 bits.JVC wrote:for sampler:
the 12-bit grit
- Real name: Max
- Gear: T1, XV 5080, ES1, Zaquencer
given that this is in samplers, I'm surprised no one's mentioned "pristine".
MIDI-ocre!CS_TBL wrote:MIDI
But I think the term comes from .mid files (I think it was called basic MIDI file format) that were compatible with old web browsers and cell phones (those infamous ringtone music) in 90s'.
- Nistegmos
- Gear: Alesis M1 Active 320 USB Monitors/Interface; Alesis Q49 USB MIDI Controller; Reaper; FL Studio; Harmor; Vember Surge; Toxic Biohazard; freewares.
- Band: Nystagmus
punchy (agree), warm (agree), organic (agree)
also, all three terms are so overused and misused as to be meaningless now.
they might as well call the sound "orange".
- mpa1104
- Gear: Finally, enough gear that exceeds the 150 character allowance. WooHoo - I qualify as an obsessed gear-head!
Or "tangerine" ?
"Transparent"
Like, it does not do anything to sound passing through it.
