Taking a short sample and making it long?
ninja6485
Band: Subliminal Sea
Re: Taking a short sample and making it long?
Post by ninja6485 » Wed Oct 08, 2014 4:46 am
pflosi wrote:Totally overkill, isn't that what we always strive for? ;)
... Oh yea! Duh! :drinks:
zardoz677 wrote:Thanks a ton to all of you for your response! I use reason which has basic samplers which can do looping but are there perhaps not more advanced samplers out there where you could take for example a little piece of a guitar hit and turn it into a long held note but not exactlly from set loop points but somehow introduce random variations of where it starts and the speed at which its played so you get this long note that has natural movement?
I'm thinking along the lines of reasons maelstrom but where you can add your own samples. Is this what alchemy or isotope iris is for perhaps?
Did you check out shortcircuit? I've been playing with it on and off all day. It's great! It has a semi-modular routing system similar to the E6400ultra that allows you to rout modulation sources to sample start time, loop positions and loop length, in addition to all of the places you might expect like the filters and egs, tunings, etc. Not sure if that's what you're looking for, but it does it, and it's free, :lol: You can definitly create a long held note out of a guitar hit that has random variations in where the sample starts from, the tuning, where the loop starts and ends, etc. Otherwise, you might be after some sort of granular/sample synthesis.
Post by madtheory » Wed Oct 08, 2014 12:09 pm
zardoz677 wrote: for example a little piece of a guitar hit and turn it into a long held note but not exactlly from set loop points but somehow introduce random variations of where it starts and the speed at which its played so you get this long note that has natural movement?
More options-
Camel Alchemy:
http://www.camelaudio.com/Alchemy.php
Or Izotope Iris (not quite what you asked for, but it's close and very cool).
Post by pflosi » Wed Oct 08, 2014 1:28 pm
Wow, Iris is looking very cool, hadn't heard of it before...
garranimal
Post by garranimal » Wed Oct 08, 2014 4:04 pm
Electro-Harmonix Freeze pedal. I do not have the freeze pedal, but my Big Sky also has this wonderful feature.
I would love to use Iris but I'm using an old windows XP machine until it runs in the ground.
ellaguru
Post by ellaguru » Wed Oct 08, 2014 5:16 pm
garranimal wrote:Electro-Harmonix Freeze pedal.
cool, didn't knew anything about this. Plus, it's not even expensive second hand.
OT
From what i saw it doesn't layers...?
Post by madtheory » Thu Oct 09, 2014 9:19 am
Why bother with a pedal, when pretty much any reverb plugin can be set to freeze/infinite?
ellaguru
Post by ellaguru » Thu Oct 09, 2014 2:04 pm
madtheory wrote:Why bother with a pedal, when pretty much any reverb plugin can be set to freeze/infinite?
well, in my purpose i saw that mostly to use it live and direct on stage (but from what i understand it doesn't layers, anyway i got some other pedal wich do that); yes, it was OT, sorry guys :)
tallowwaters
Gear: LC-MS/MS
Post by tallowwaters » Thu Oct 09, 2014 5:07 pm
My smart a*s answer was to press the keys all the way to the left of middle C. "Makes" the sample much longer.
Really though, set loops, cross fade, reverse after crossfade (or reverse crossfade), add some LFO with a slow attack envelope with variations to pitch, amp, whatever. FX help too.
Remember, cross fading is not a crutch for shitty looping, which is an art in and of itself.
Zamise
Gear: Rollhand P00
Band: Quantum-Source
Post by Zamise » Fri Oct 10, 2014 6:56 pm
I don't think there are many samplers that have a random start loop point feature. Only one that I know is the RT Spectralis. I'm sure there are much cheaper options and methods. I like the LFO idea. Don't necessarly need random start stop if you've got a decent LFO. You might be looking more for a "chop" or "sample slice" feature too than a random start point. Yamaha RS7000 is my go to machine for everything but I'll stop there unless you want to hear more about it.
Post by pflosi » Fri Oct 10, 2014 7:22 pm
The V-Synth can advance the start point through the transients of a sample with each new keypress... Different but I thought I'd mention it anyways. Can produce some very interesting results.
ellaguru
Post by ellaguru » Fri Oct 10, 2014 7:34 pm
pflosi wrote:The V-Synth can advance the start point through the transients of a sample with each new keypress... Different but I thought I'd mention it anyways. Can produce some very interesting results.
cool, i have to try that absolutely! maybe is also on the manual?
Post by pflosi » Fri Oct 10, 2014 9:20 pm
On the (pcm) osc, set "playback mode" to "step" (or "event" if you wish).
P. 87 in the XT manual, no idea about the V-Synth 2... But I guess it's hardly any different.
ellaguru
Post by ellaguru » Fri Oct 10, 2014 11:44 pm
nice! thanks
Post by madtheory » Sat Oct 11, 2014 10:07 am
Emu samplers can map start point to velocity. OK, not random- but maybe better. Most of the Ensoniq samplers gave you a lot more mod options for sample start and also loop point.
ellaguru
Post by ellaguru » Sat Oct 11, 2014 11:21 am
madtheory wrote:Most of the Ensoniq samplers gave you a lot more mod options for sample start and also loop point.
i have an asrx too, i have to undust it and check the manual again and see if that is possible to do with it. Thanks.
@pflosi
yes, i read rapidly on the Vsynth manual, it's the same as for on the XT
