EMU 4000 Hard disk questions
ninja6485
Re: EMU 4000 Hard disk questions
Post by ninja6485 » Tue May 02, 2017 4:45 pm
An additional note to try to figure out if it actually is the scsi thing, I have 5 other samplers that use the same disks and drives, and they all work reliably.
talkboxert
Post by talkboxert » Fri Jan 11, 2019 11:29 am
Hi There,this seemed like an appropriate place to post this.
I Just installed an internal quantum fireball (2GB) in my ESi-4000 (OS 3.02) I took the power from the floppy connector, thus disabling the floppy.(this should be no problem I guess?)
I Can now mount the drive, format it, so I did and used "copy file system" (option 8) in the hidden menu.
But when I want to save my bank it still says "no Esi file system mounted".
The HD is in it's default state, that means termination = on and ID = 6.
I already tried different ID's for the ESI itself, but just wondering if there's something I'm missing?
Should the floppy be kept "in the loop"? Should I unterminate the HD or try a different ID? Or use one of the "deinterlaced" format options from the hidden menu? :banghead:
talkboxert
Post by talkboxert » Fri Jan 11, 2019 2:05 pm
Ok it was the quantum manual not being clear. Still needed to set a jumper by hand to terminate, now it works. :keys1:
Post by madtheory » Fri Jan 11, 2019 2:13 pm
Nice machine. I'm starting to regret selling mine. Had a few unique sounds for it that don't translate to Kontakt.
