does this hardware exsist? a rack that shifts MIDI back/forw
You know how in cubase you could move forward or back MIDI information a touch forward or a touch back, like 000.1ms or most kind of thing on separate midi channels. Is there a rack that'll do this? back is probably logically impossible but hopefully forward.
I know there's them Mark of the unicorn timepeice thingies, would that do it?
- meatballfulton
- Gear: Logic Pro X
Re: does this hardware exsist? a rack that shifts MIDI back/
If I had the technology to move the MIDI stream forward in time I would be a trillionaire.
- madtheory
- Real name: Tomas Mulcahy
Forward in Cubase is simply later in time. It's just a delay. Backwards is a little bit more challenging
So you want to do this for live playing? That's nonsensical. Or with a hardware sequencer? A lot of sequencers have that built in, what do you have?
- Jabberwalky
- Gear: A hybrid of vintage and modern junk
- Band: Variar
The midi merger I have MX8 does something like that. Kinda useless. Also, the merger died on me so can't check for sure.
- Stab Frenzy
Akai midi delay does it back in time, nothing does forward, obviously.
- Real name: Max
- Gear: T1, XV 5080, ES1, Zaquencer
No not playing live. I'm using some very dated technology. an Amiga with OctaMED (with the only MIDI tools being note on/off and velocity
) and various Akai s-series samplers and romplers.
thanks for the suggestions that MEP-4 looks interesting if it's not a fortune to get 2nd hand.
I guess a backwards in time just selects all other alternative midi tracks and delays them after hitting play? not sure really.madtheory wrote:Forward in Cubase is simply later in time. It's just a delay. Backwards is a little bit more challenging
- Stab Frenzy
There's been an Akai ME10D in my local music shop for $70 for as long as I remember. You should be able to get something similar for next to nothing.
Another worth mentioning is the Mutable Instruments MIDIpal, can do just about anything to a midi stream that you can think of, barring time travel of course.
- Gear: juno106 korg ms20 roland vsynth yamaha an200 yamaha tx81z boss sp303 boss sp505 roland sp606 roland mc909 zoom st224
rs7000 and an/dx200 or maybe rm1x do that, but maybe i hadn't understand well the question...
ok well I'm not looking for actual midi 'DELAYS' I got various alesis fx processors for that stuff. so I'm not looking for things that shift the midi into endless feedback delays. Just shifting ONCE to fix things in the groove............... if that makes sense.
- sneakthief
Aphex Feel Factory
sneak-thief: raw electrofunk!
http://sneak-thief.com
- Jabberwalky
- Band: Variar
You've gotten a lot of suggestions. What else are you asking?
