Roland SP-404/SX questions
OlicanRacer
Post by OlicanRacer » Mon Apr 20, 2015 7:19 pm
I play electric bass and wanted a sampler to use as a live pad for samples while i am playing. i am heavily into effects pedals. i see that the 404-sx can only use one effect at a time. can i do some kind of send/return loop into my effects pedals to use more than one effect or other effects on a sample?
one of my pedals is a loop station and can record one track with the capability of over dubbing on the fly.
OlicanRacer
Re: Roland SP-404/SX questions
Post by OlicanRacer » Wed Apr 22, 2015 1:48 am
i guess nobody here posts here or knows nothing about nothing?
Post by Stab Frenzy » Wed Apr 22, 2015 2:04 am
Yes you can run the 404 into your effects pedals. Of course you can, you can run anything with an audio output into effects pedals.
monolith
Post by monolith » Wed Apr 22, 2015 3:39 am
You can also put an effect on a sample, then re sample it to another pad, then add an effect to that, then resample and so on....
Real name: Unpronounceable
Band: Eridani V
Post by Ashe37 » Wed Apr 22, 2015 4:16 am
and people say Stabby is the mean moderator.
moremagic
Real name: A.M.
Post by moremagic » Fri May 01, 2015 6:11 am
sunce when can the 404sx only use 1 effect at a time? do you mean one per sample? because different samples can have different fx, and as mentioned above theres always resampling
i guess all those jokes about bass players must be true!
