Crumar Bit 99 - should it Sound this way?
kawaiicroc
Post by kawaiicroc » Fri Jul 12, 2019 2:15 am
First post! I just got a Bit 99, and all seemed fine at first, but I noticed when I have a sound with ramp or triangle added, there is a ringing sound over top of the note played. The ringing is actually in tune with the note played and is only apparent on the lower notes.
At first I thought maybe this was normal, but I don’t hear it in any other demos that I’ve listened to. Can other Bit 99 users attest to this?
Re: Crumar Bit 99 - should it Sound this way?
Post by madtheory » Sat Jul 13, 2019 11:24 am
Welcome here! Yes they do this, kinda sounds like aliasing on a sample. If you could post an audio example, just to be sure, that would clear things up right away.
kawaiicroc
Post by kawaiicroc » Sat Jul 13, 2019 5:17 pm
Aliases is exactly what it sounds like. I will post a clip, but I think you nailed it.
