Problems with encoder Oberheim Xpander
maurizio
Post by maurizio » Fri Feb 24, 2017 7:51 pm
HI
I have a Oberheim Xpander with encoders that do not work in a proper way. When you rotate the encoder the value sometimes does not change, or increases or decreases in an exaggerated way or instead of increasing it decreases, etc.
I replaced all the encoder, and the encoder no. 6 I have also replaced the 0.1 uF capacitors by also adding a further 0.1 uF capacitor in parallel, but its behavior does not change.
In your opinion what is the problem? Thank you.
