Casio CZ-101 - need help with setting up
Postby KidFromBastion » Tue Sep 05, 2017 7:01 pm
Hey everyone!
So, I got myself a Casio CZ-101 today and its either broken, or I have no idea how to use it.
Fom what I read in the manual, when I turn it on, I should see the first default preset.
What I have instead is WRITE SELECT MEMORY message. When I choose memory number, I got WRITE OK message and thats it. None of the buttons do anything, except Portamento on/off lights up when I press it :P .
I tried pressing every button and combination, I cant access any other memory bank or get rid of WRITE OK message. Manual says that it should disappear right after I lift my finger from WRITE button, but of course it just doesnt work.
Is there anything that I could have missed? Or is my synth simply broken ? :(
Re: Casio CZ-101 - need help with setting up
Postby madtheory » Tue Sep 05, 2017 9:15 pm
First thing to try- switch synth off, find the "P" button on the underside, get a ballpoint pen, use it to keep the P button pushed in, and switch the synth on. This resets it.
Now does it work OK?
If that doesn't help, then it sounds like the WRITE button is faulty (stuck "on"). Bit fiddly to fix. How's your electronics?
Band: madtheory
Postby Rasputin » Tue Sep 05, 2017 10:03 pm
This could definitely help you: ... air-guide/
My wild guess is that it is the tri-state buffer, but that might not make sense depending on how the other buttons respond or don't respond. If so, that part is quite inexpensive, but a tad tricky on the soldering. Well, the desoldering, really. Easier to use micro-cutters to shear the pins and then remove the pins one-by-one and then just drop the replacement chip in.
Or, if you're lucky, it's just physically stuck somehow. Try jamming on the Write button a couple times.
Return to HELP!
Users browsing this forum: No registered users and 11 guests
