Roland D10 connector disconnect
Postby daT0nkee » Fri Mar 16, 2018 12:40 pm
Dear all,
I have a little problem disconnecting the white connectors on the Roland D10 main board.
Do anyone knows how to do this?
Happyness,
daT0nkee
Re: Roland D10 connector disconnect
Postby charles » Sat Mar 17, 2018 11:54 am
hi ,,I have 2 d10 ,,which connector the white ribbon cable or the white flex shield ribbon?
charles
Postby daT0nkee » Sat Mar 17, 2018 1:40 pm
"which connector?
The red ellipse marked ones. I dont think the yellow marked connectors are disconnectable.
daT0nkee
Postby charles » Tue Mar 20, 2018 10:51 pm
I know how to do it barbarian style ...hence not sure what the correct tool is for the job ,,,,,these are a type of clamp connector...if you can visualise a horizontal guillotine which doesn't quite cut all the way that's exactily how these connectors chambers grasp the wire .....so once you pull up the outer plastic shield..held down by small tabs on the sides of the connector it frees the grasp on the wires,,,typically I kinda warm up the plastic mildily and with a large safety pin deactivate the latch tabs which hold the plastic tops down .....
good luck these plastics are so brittle with their age .......most come out easily if I remember ..its been about 8 years since ive been in my d10/110 u20 etc I forget if they all come off or not
charles
Postby Mr_Mojo_Risin » Sat Mar 24, 2018 7:02 pm
I think the the U-20 has a similar connector.
These are called Wire Trap Connectors are are appropriately named :evil:
It's not easily to see how these work at first glance.
Press down on the top using a small flat-blade screwdriver and then pull the cable out.
Here is a link with a diagram showing how to disconnect those @!#%ing cables.
http://llamamusic.com/u20/u-20_info.html#strangeconn
Equipment List;
Roland MKS-70. MKS-50, U-20, U-110, D-110, S-50, S-550, JV-880, GR-1
Yamaha FB-01
Kawai K1r
PGH 10+1 x 2
Art SGE Mach II
Akai ME20A, ME30P
Mackie LM-3204
PAiA 6710
Fostex 3010, 3011
Mr_Mojo_Risin
Gear: MKS-70, JX-10, MKS-50, U-20, S-50, S-550, W-30, JV-880, GR-1, U-110, D-110, FB-01, Kawai K1r, PGH 10+1 x 2, ME20A, ME30P, LM-3204
Band: Factorial
Postby charles » Mon Mar 26, 2018 12:38 am
I have been known to be wrong ,,, think there are two types ?
mine didn't release the wires so I disassembled the two parts of the sheilding
charles
Postby daT0nkee » Fri May 25, 2018 8:49 am
Oh, at least i was able to understand. My bad. And it was in the service manual too.
daT0nkee
Return to HELP!
Users browsing this forum: No registered users and 18 guests
