Hohner/Elex K4 need info on power supply build
Brian G
Post by Brian G » Thu Apr 19, 2018 4:00 pm
Help!!!!
the power supply is ify at best, and the cord connector at the back of the keyboard is awlful, did some soldering works, ground appear good, but still getting some noise and hum..caps? any help would be appreciated, the pedal on the external power supply does not work, really do not need it I guess, any plans for a new build power supply would be appreciated, thank you.
Re: Hohner/Elex K4 need info on power supply build
Post by madtheory » Fri Apr 20, 2018 8:34 am
You will need an oscilloscope to check for ripple in the supply. Likely the caps, yes, but could be rectifiler fault too. Don't guess. Test.
adamstan
Real name: Adam
B5 DIY polysynth
KORG Poly61
Vermona DRM
Solton Programmer 24
LEMA EDD-5
Post by adamstan » Fri Apr 20, 2018 3:29 pm
My Elex was humming too, but the bad capacitors weren't in the PSU - they were on chorus boards.
