D-50 Part
Posted: Thu Oct 04, 2018 7:54 pm
by Moog_Meister
Does anyone know where I can get some key guards like this? Tech serviced my D-50 and threw these away.
An example of what I’m talking about:
https://goo.gl/images/j3oBCD
-Thanks
Re: D-50 Part
Posted: Thu Oct 04, 2018 10:29 pm
by madtheory
Looks like thin PVC, you could cut your own strip from a sheet? I'll take a look at my D50 at some stage, when I get it out of storage.
Re: D-50 Part
Posted: Fri Oct 05, 2018 12:39 am
by Moog_Meister
madtheory wrote:Looks like thin PVC, you could cut your own strip from a sheet? I'll take a look at my D50 at some stage, when I get it out of storage.
Thanks for the reply. I’m not too sure it’s definitely a flexible plastic of some sort. If I could nail down what material it is I could cut out some put them in.
Re: D-50 Part
Posted: Fri Oct 05, 2018 11:58 am
by madtheory
OK if I get a chance to check mine I'll let you know but I can't make any promises might be a week or two...
Re: D-50 Part
Posted: Fri Oct 05, 2018 12:03 pm
by Rasputin
What's with people and their compulsion to throw things away? smh :roll:
Mylar stencil sheets are the first thing that come to mind.
10 mil maybe? 14 mil is probably too thick. If I recall correctly, those strips aren't that rigid, just enough to keep the keys from being pulled out. Luckily for you, I think a pretty wide range of materials could be used here and it won't much matter.
Re: D-50 Part
Posted: Fri Oct 05, 2018 3:20 pm
by Moog_Meister
madtheory wrote:OK if I get a chance to check mine I'll let you know but I can't make any promises might be a week or two...
Hey, no rush I just appreciate the help. Thank you for going through the trouble.
Rasputin wrote:What's with people and their compulsion to throw things away? smh :roll:
Yeah I don’t get it! I worked on my Alpha Juno 2 and all it took was a little Elmer’s glue to put the guard back in place. One good thing from the experience with this tech is I learned to work on my own gear so I can have everything the way I like it. Thanks for the suggest I will look into stencil sheets.
Re: D-50 Part
Posted: Tue Oct 16, 2018 11:45 pm
by upunkt
You can use basically any flat plastic like cheese packaging or likewise cut to stripes. Make sure to attach the stripes properly with doublesided tape, gaffa or sth similar.
Re: D-50 Part
Posted: Wed Oct 17, 2018 6:49 am
by Yekuku
These plastic strips hold the keys from popping off.
It is not a critical part , and it looks like most people are lazy enough to put them back in place.
1mm thickness is ok, and they can be attached with double sided tape as upunkt said.
Any hard plastic can be used, just look in your trash bin , I am sure you ll find something appropriate for the job ;)
Re: D-50 Part
Posted: Wed Oct 17, 2018 7:52 am
by Moog_Meister
Thanks for the help and suggestions, guys!
