Cheetah MD8, loading sounds
Postby Kentronix » Sun Nov 11, 2018 8:00 pm
Hello everybody peeps !
I have been trying to revive my old Cheetah MD8 drum machine recently, I have got to the point where it all seems to work but the drum sounds are corrupt, which isn't surprising, I got hold of a wav file of the original sounds tape for it but I cant get it to work.
Playing from a PC into the Cheetah I cant even get it to recognise that its a file let alone successfully load it. Has anybody managed this ? Does anybody have any tips for loading wav's into old tape based devices ?
Its an un-encoded wav and I have all sound enhancements in windows turned off.
Find the date of your vintage Roland gear
Kentronix
Gear: ABL3. Waldorf Rocket, MicroBrute, Volca Bass x 2, Volca Keys, Volca Beats, Rhythm wolf, Boss DR-550, Korg Delta, Yamaha DX-11, Roland D110, Reaper DAW
Re: Cheetah MD8, loading sounds
Postby madtheory » Sun Nov 11, 2018 10:30 pm
Have you tried adjusting the level going in? Are you using a mono cable?
Band: Minim
Postby Kentronix » Sun Nov 11, 2018 10:39 pm
Thanks for your reply.
Yeah, I tried starting really low, then turning it up a bit and trying again, etc. Spent about an hour doing this.
Yes, I was using a mono cable. I have no idea what kind of output those old computer tape decks were, line level I assume, I guess my PC could be auto sensing or something, its a line/headphone socket.
The machine itself is very basic I assume at some point it should spot a file coming and display its filename on screen.
Kentronix
Return to HELP!
Users browsing this forum: No registered users and 13 guests
