Setting up synth
inuse_
Setting up synth
Post by inuse_ » Thu Feb 14, 2019 7:39 pm
Hey, ameteur question. I own a korg ds 8, what do I need to connect it to ableton?
tim gueguen
Re: Setting up synth
Post by tim gueguen » Thu Feb 14, 2019 11:36 pm
You'll need some sort of audio interface to record the sounds. To send and receive MIDI data you'll need a MIDI interface. Some audio interfaces also have MIDI connections.
inuse_
Post by inuse_ » Fri Feb 15, 2019 12:03 pm
tim gueguen wrote:You'll need some sort of audio interface to record the sounds. To send and receive MIDI data you'll need a MIDI interface. Some audio interfaces also have MIDI connections.
Any recommendations under £70?
Band: Minim
Post by madtheory » Fri Feb 15, 2019 8:26 pm
What computer do you have?
inuse_
Post by inuse_ » Fri Feb 15, 2019 9:33 pm
madtheory wrote:What computer do you have?
MacBook Pro mid 2010
Band: Minim
Post by madtheory » Sat Feb 16, 2019 4:34 pm
Getting audio in and out of that with the built in port is a pain in the a*s as it cannot do both at the same time because it is a combo port.
Spend a little more than £70 and treat yourself to a Focusrite Scarlett 2i2. Has MIDI ports and really good audio in and out.
