Help with synthesizing a high pitched hissing sound
Hello, any idea's to get me in the ball park? I know noise will be a component but I'm just not getting a high pitched hiss sound. Thanks for any help. Cheers
- Weirdofromouterspace
- Real name: Bodo
- Gear: MFOS SLMS+ & Ultimate, TTSH, DX7IID, DX21, Minibrute, Poly-800, microKORG, microSAMPLER, Volca Beats & Bass, JX-03, Tr-8, Kawai K1, Jasper
Re: Help with synthesizing a high pitched hissing sound
White noise (since it features all frequencies) through a HP filter
Thanks for your reply. I tried that this morning and has helped me get a bit closer. I still can't seem to get that sssss or well defined hiss sound. I'll keep tweaking, thanks again.
- Real name: Bodo
Don't know if that's what you're after, but high resonance settings can lead to really cool soundsdajones wrote:Thanks for your reply. I tried that this morning and has helped me get a bit closer. I still can't seem to get that sssss or well defined hiss sound. I'll keep tweaking, thanks again.
Thanks again. I'll play with that and see if I can get any closer.
- pflosi
Non-appropriate switching PSU powering any audio device? Bonus points for using unbalanced cabling.
- Big Gnome
- Gear: E-mu Proteus 2500
Ensoniq ESQ-1
Ensoniq VFX
SCI Prelude
Waldorf Blofeld - Band: The Nondescript
Hard to say without a clearer idea of what type of thing you're after. I can't think of a more appropriate approach than the aforementioned white noise through HPF thing for a static, undifferentiated hiss. (A BPF with high resonance--or a few in parallel--might be a useful variation thereupon.) For more of a mechanical/electrical whine, I'd suggest something similar with a comb filter to bring out some annoying resonances. Alternately you might try something with one or more narrow pulse waves through a BPF with noise modulating the cutoff frequency. Or you could experiment with FM using high/non-integer ratios; or sample rate reduction to generate aliasing artifacts...there are a bunch of ways to get those sorts of sounds. I hope that provides some food for thought.
Some of my c**p
Some of my c**p
- iowagold
- Gear: 4) korg RADIAS-R on big rack, 4) roland integra7, 4) SC-55 4 studio rooms.
hey dajones quick question, and a good one too!!dajones wrote:Hello, any idea's to get me in the ball park? I know noise will be a component but I'm just not getting a high pitched hiss sound. Thanks for any help. Cheers
what make and model of synth do you have??
Paul in Iowa
