Novation Supernova 2 issue
Behnam
Post by Behnam » Tue Oct 29, 2019 8:18 pm
Hi all,
i hope this is the correct area to post, apologies if not.
i have just got down my SuperNova 2 from my mums attic (been up there for about 10 years!!). it was all fine when i stored it. however, now when i turn it on i just get all thes flashes lights and nothing happens. have a look at the youtube video.
[YOUTUBE] [/YOUTUBE]
Does anyone have any idea what this could be and how i could fix it? i have contacted Novation and they asked me to send it to them. It does seem exspensive though which i undertsand but thought i'd post here first.
Many thanks,
Real name: Unpronounceable
Band: Eridani V
Re: Novation Supernova 2 issue
Post by Ashe37 » Tue Oct 29, 2019 8:53 pm
you need to make the video not private.
Behnam
Post by Behnam » Tue Oct 29, 2019 9:50 pm
Thanks for the heads up, hopefully you can see this video now?
Band: Eridani V
Post by Ashe37 » Tue Oct 29, 2019 10:57 pm
yes, it works now. IS there a hard reset procedure for the supernova 2? has its internal battery died?
Behnam
Post by Behnam » Tue Oct 29, 2019 11:09 pm
Googled that, tried it and nothing :(
blueknob
Gear: ESi32/E6400U, Novation Supernova, Ensoniq, vintage Macs and the like.
Post by blueknob » Wed Oct 30, 2019 9:17 am
Isn't step one to check the power supply? Reach for the DVM check 5V12V -12V whatever there might be? I suppse whilst DVM in hand check battery backup voltage too, many are 3V.
Yekuku
Post by Yekuku » Wed Oct 30, 2019 2:29 pm
Hi and welcome to the board.
It looks like the unit freezes during boot.
I have seen this before and the culprit was either the ribbon cable or a bad Ram IC.
You can try this , but I doubt that it will work:
How can the Supernova/SuperNova II be completely reset?
To restore the operating system of a Supernova or Supernova II, hold down part edit button 6 while you turn the synthesiser on. The display will show "reload O/S from ROM to flash?". Push the page up button to accept this prompt. The reload should take around 5 seconds.
Once the reload is complete you can restore the factory settings for the Supernova or Supernova II. To do this find the local control & memory protect page in the global menu. Ensure that local control is turned on and memory protect is turned off. Press the page up button to advance to the restore from ROM page of the global menu. Use the fast data controls to select "total data" as the option to be restored.
Push the write button twice to initiate the reload. This reload takes around 15 seconds. Once the reload has taken place, the memory (not the buffers) will have been initialised. Turn the Supernova off and back on again or advance to a new Program / Performance to clear the buffers. The items that are restored are: Program banks A-D, Performance banks A-B, Drum Banks a-d (Supernova II only), all arp patterns and the global menu data. Program banks E-H, Performance banks C-D, Drum Banks e-h cannot be restored as these are not stored in ROM.
So next try this:
1) Check the PSU
2) reattach or replace ribbon cable.
3) Replace Ram IC ( tricky smd component to replace , not for the fainthearted)
p.s. concerning the Ram IC, there are 3 of them installed, if you cant figure out which one has the problem, then you should replace all of them.
It is all about sharing...
shadowmask
Gear: Yamaha: SY85, TG-500, TG-300, MOXF6, FG410
Novation: Supernova II Keyboard & Rack Pro-X
Post by shadowmask » Fri Dec 13, 2019 4:49 pm
Hi,
I put a reply for this over at Gearslutz, I'll paste it in here for reference:
This means one of the DSP ICs has not responded during the boot sequence.
Sometimes the SNII may randomly halt during the boot, but if it always shows the same sequence of lamps (Parts 1 thru 7) then it is very likely a DSP fault.
Brian
