Roland D50 operates very slowly
mIIwaukee
Gear: Oberheim and Roland gear
Post by mIIwaukee » Sun Feb 02, 2020 12:06 am
I got a D-50 for a great deal, but it’s inexplicably slow. Boot up time takes a few minutes.
Once booted key panel presses take 30 seconds to register. Keyboard works after long delay (it does sound pretty awesome). It passes all startup tests except for the joystick/bender/mod/ext test. They may move too “fast” to register... idk. Midi works, it kinda takes a sysex file or at least enough to load a patch.
Here is what Ive tried so far without success:
System Reset
Cleaned the circuit boards
Replaced the battery
Disconnected cables from the main board to other boards
Replaced capacitors on the PSU
Replaced the 12mhz crystal
Examined the main board closely for faults
Reseated the eprom
Any other suggestions on what I might try?
Yekuku
Re: Roland D50 operates very slowly
Post by Yekuku » Sun Feb 02, 2020 1:32 pm
hi and welcome on the board.
if memory serves me right there are 2 crystals on the d50 mainboard.
Can you measure their frequency?
Relativelly new cheap multimeters can read frequencies up to 50 MHz
It is all about sharing...
mIIwaukee
Post by mIIwaukee » Mon Feb 03, 2020 2:26 am
Thanks Yekuku. I’ve ordered a scope to test. I will report back once I get it setup.
Yekuku
Post by Yekuku » Mon Feb 03, 2020 11:32 am
I have heard that if you reverse the pins of a problematic crystal oscillator , it might start working again.
Since you are waiting for an oscilloscope to arrive, you can try this on the 2nd crystal and see if sth changes.
