Line noise in Kurzweil K2000
hudkins
Post by hudkins » Thu Feb 20, 2020 7:04 am
I have a Kurzweil K2000 with noise in the line level mix outputs. A 60hz hum and some low level static. I recently acquired the synth. I've checked as many grounds as I could find and they seem alright. What else can I look at? Would recapping be a good idea? What else can I look at?
My synth repair knowledge on a scale of one to ten is about a 3.
Any help is appreciated. Thanks!
Yekuku
Re: Line noise in Kurzweil K2000
Post by Yekuku » Thu Feb 20, 2020 9:08 am
Concerning the hum issue , sounds like a problem with the filter caps in the power supply.
About the static noise, it should be the infamous output JFETS dying.
It is all about sharing...
hudkins
Post by hudkins » Fri Feb 21, 2020 8:56 pm
Thank you! I'll look into those.
