Korg sq 1 compatibility
Redsourstraw
Post by Redsourstraw » Thu May 14, 2020 12:41 am
Just picked up an sq 1 from a friend and curious to the compatibility. I have an electribe and a Cs-01 at home can I use? Or do I need a volca piece. If anybody wants to help by telling me what I can use, preferably in the cheaper range if the electribe or CS-01 won’t work let me know
Weirdofromouterspace
Real name: Bodo
Re: Korg sq 1 compatibility
Post by Weirdofromouterspace » Thu May 14, 2020 10:19 am
The SQ-1 is a cool little step sequencer - I use mine mainly for my DIY Syncussion :D.
However, a 1*16 or 2*8 step sequencer imho doesn't make much sense with an Electribe (regardless which one it is), and the Electribes have on-board sequencers anyway.
Using it on a Yamaha CS01 requires the latter being modified to accept external sequencer inputs, since that synth originally has neither CV/gate nor MIDI inputs. In other words: It is simply impossible to connect an external sequencer to an unmodified Yamaha CS 01.
The SQ-1 works with many synths (not only the Volcas), but - as pointed out above - it is not a good choice for an Electribe, and only suitable for the CS 01 if the latter is modified so it will accept signals from a sequencer.
Redsourstraw
Post by Redsourstraw » Thu May 14, 2020 6:35 pm
So anything midi could be controlled by the sq-1? I have a cheap little electric piano keyboard thing with midi wonder if that could be controlled? Sorry I’m pretty new to this. I know it’s not a stand alone unit but could I sequence things in GarageBand?
Real name: Unpronounceable
Band: Eridani V
Post by Ashe37 » Thu May 14, 2020 6:50 pm
does it have one midi port or two? a lot of those that i have seen only have midi out
Redsourstraw
Post by Redsourstraw » Thu May 14, 2020 8:17 pm
This particular unit has midi in and out. So midi cable coming out of sq-1 into the midi in on the keyboard should work?
Band: Eridani V
Post by Ashe37 » Thu May 14, 2020 8:19 pm
yes but be aware you need to see what channel the sq1 is sending on.
Redsourstraw
Post by Redsourstraw » Thu May 14, 2020 11:35 pm
If you could explain more I’d be grateful
Real name: Bodo
Post by Weirdofromouterspace » Fri May 15, 2020 9:11 pm
Basically yes, but only single notes and not chords, since that's all the SQ-1 can provide.
Re: channel
MIDI equipment is able to send and/or receive MIDI on 16 different channels. Both sending and receiving units must be set to the same chalnnel or they won't be able to commuinicate (think of it like voice radio, in a way). It may be possible to set the receiving (slave) unit to "all chanels", which means it will "listen" to whatever commands are coming in through MIDI.
Using different channels can for instance be used to daisy chain instruments, such as
SQ-1 -> Instrument X -> Instrument Y,
with the SQ-1 going into the MIDI in of instrument X, and MIDI Thru of Instrument X is connected to MIDI in of Instrument Y. Setting the SQ-1 to one of the 2 channel modes will now make the SQ-1 sendi channel A data on one MIDI channel and channel B data on another MIDI channel.
Let's say you set SQ-1 channel A to MIDI channel 1, and SQ-1 channel B to MIDI channel 2...
... and instrument X to MIDI channel 1 and instrument Y to MIDI channel 2. You will now be able to control instrument X wich SQ-1 channel A, and instrument Y with SQ-1 channel B.
