Juno 106 voice issues
AJ77
Gear: D-50, JD 800, Juno 106, CS1X, DX7
Post by AJ77 » Fri Jun 12, 2020 11:27 am
Hi everyone, I am hoping that somebody might be able to help me.
I have a Juno 106 that developed a voice problem a few months ago. All voices would work fine, but after 20 minutes or so, voice 4 would fade out and make pops and weird noises.
I first tried de-soldering all of the voice chips and soaked them in acetone to remove the coating. I did not noticeably damage any traces or components on the board. After the coating came off the chips and I put them back in to the board, only voices 1 and 4 would sound. On test mode, on some settings like square 3 voices would sound, but on the lower sounds only 2 would sound, and different to the ones that sounded on square.
I bought new digital voice chips, and when they finally arrived and I installed them, the same issues were there. I thought it could be the 3 D5534A chips that were faulty, so I bought the new digital versions of them. The same issues persist.
I then replaced the Mitsubishi amplifier chip, but still no change. I have checked resistors and capacitors and nothing that I can see seems to be damaged or faulty.
Is there something on the board that I am missing, or could it be an issue from somewhere else in the Juno?
Any help would be greatly appreciated.
Real name: Unpronounceable
Band: Eridani V
Re: Juno 106 voice issues
Post by Ashe37 » Fri Jun 12, 2020 3:31 pm
'new digital versions'?
synthchaser
Post by synthchaser » Fri Jun 12, 2020 7:25 pm
I would assume he means new surface mount clones.
To the OP, I would recommend using an oscilloscope to find what your actual problem is before guessing and changing stuff. You may wind up doing more damage than good.
AJ77
Post by AJ77 » Sat Jun 13, 2020 10:07 am
With the COVID-19 issue I couldn't send it off to anyone to look at it, so I assumed it was the common issue with the coating on the voice chips. It's obviously something else, so I am not going to do anything to it until I can get it checked out properly. Thanks for the reply and the advice.
AJ77
Post by AJ77 » Sun Jun 14, 2020 2:41 pm
Sorry for not being clear in my OP.
I replaced the original chips with these modern clones:
http://www.analoguerenaissance.com/D80017/
Band: Eridani V
Post by Ashe37 » Sun Jun 14, 2020 10:43 pm
They aren't 'new digital versions' any more than the original chips were digital. Hence why i didn't know what you were talking about.
