Roland U20 MIDI not working
eirianwhopkins
Post by eirianwhopkins » Tue Jul 07, 2020 4:00 pm
Hi. Recently bought a Roland U20 in need of some TLC. Fixed keys, replaced battery and managed to reload factory patches over MIDI.
However, since then I have been unable to send or receive MIDI data via my audio interface to my DAW (Reaper).
Tried following the instructions in the manual to set the various options for MIDI on the U20 but nothing comes up in the DAW and then the Asio driver crashes and I have to restart the computer.
If anyone has any ideas for a solution I would be very greatful as the U20 was bought to use as a MIDI controller.
Real name: Unpronounceable
Band: Eridani V
Re: Roland U20 MIDI not working
Post by Ashe37 » Tue Jul 07, 2020 8:40 pm
You have both audio and midi cables connected, right?
Yekuku
Post by Yekuku » Tue Jul 07, 2020 10:19 pm
Recently bought a Roland U20 in need of some TLC. Fixed keys...
When you fixed the keys , could it be that you disconnected accidentally the ribbon extension on the left side?
This connection is not meant to be disconnected, it is held by conductive adhesive tape that is not reusable.
It is all about sharing...
Post by meatballfulton » Wed Jul 08, 2020 12:11 am
If you got the patches into the unit, then at least the MIDI from computer to U20 is working. If it's not responding to MIDI notes from the computer, start by looking at all the channel settings (again). The patch load is not channelized and it got through.
See page 149 of the manual about the MIDI monitor function.
eirianwhopkins
Post by eirianwhopkins » Wed Jul 08, 2020 12:10 pm
Was thinking it was maybe the audio interface but manage to get that working with a different device.
Seems to be working better now but still have intermittent issues.
Will keep trying. Thank you all for your input.
eirianwhopkins
Post by eirianwhopkins » Fri Jul 10, 2020 1:10 pm
Hi guys. I believe that the problem was that the audio interface (M-audio Fast Track Pro) was not working properly when sending midi data to Windows 10. Driver issue apparently! I'm trying a basic interface lead now and so far everything sounds ok.
