prophet rev 2 -- song mode / pattern chaining?
hotbird
Post by hotbird » Wed Jul 15, 2020 11:31 pm
is anyone aware if the prophet rev 2 has a song mode, or the ability to chain different sequence patterns together? i could've sworn the band in the video below was chaining simple drum patterns together (i didn't see a drum machine anywhere on stage). the only gear was a prophet rev 2 and an alesis q49 midi controller.
many thanks for any help! this is driving me crazy! :shock:
Re: prophet rev 2 -- song mode / pattern chaining?
Post by meatballfulton » Thu Jul 16, 2020 12:12 am
No it does not have a song mode, but since each patch has it's own sequences, they can be chained in a manual fashion by doing program changes. That could be what the band in the video is
doing, since most MIDI controllers can be set up to send program changes. I used to do this with my Evolver.
The OS allows copying sequences beteen patches (same sequence, different sound) or sounds between patches (same sound, different sequences). Because it's bi-timbral, both the A and B layers have their own sequences. It's nowhere near as flexible or easy to use as a true song-based sequencer, but it can be done.
hotbird
Post by hotbird » Thu Jul 16, 2020 4:58 pm
thank you! that sounds about right... the patterns were pretty simple so i suspect they could be achieved in this fashion. thank you for your time & info.
