LCD display replacement (Roland MKS-50)
logix
Post by logix » Sat Oct 10, 2020 5:24 pm
The display backlight of my MKS-50 looks kind of weak and it might be time to change the display entirely. Does anyone have any info on how and which replacement display works?
Rasputin
Re: LCD display replacement (Roland MKS-50)
Post by Rasputin » Tue Oct 13, 2020 8:40 pm
Some cheap 16x1 LCD with LED backlight such as,
https://www.crystalfontz.com/product/cf ... KsFcN7COMs
or a 16x1 OLED, but this requires also replacing the MKS-50 firmware to make it compatible.
http://zine.r-massive.com/roland-mks-50 ... -firmware/
logix
Post by logix » Tue Oct 13, 2020 11:14 pm
Thanks.
So a standard HD44780 type 16x1 display?
Are the pinouts identical?
The service manual says the display is a DM011Z-1DL3, but there aren't any pinouts or other details there, nor am I able to find anything online about it.
I remember messing around with a Roland D-110 LCD replacement where the connection was almost the same as with the original one. Fortunately I got a lot of good help here and it worked out in the end.
