Good Day.
The other day I notice my beloved D50 performs just fine for about 5 minutes and then slides out of tune by about a 1/2 step. The master tune setting doesn't change. It's not controlling anything or being controlled by anything. Just mono output to line in on my amp. When I turn it off and let it sit for a bit, it comes back "in tune" before drifting out of tune again.
Reading other posts about D10's I am wondering if this might be a sign of a loose/dirty connection on the board somewhere.
Any educated guesses? I am searching out local techs who might be able to service it, but would like to know more before simply dropping it off at a local shop.
Thank you in advance for any help the group might be able to provide.
DWM
Roland D50 Drifting Out Of Tune
- Gear: ESi32/E6400U, Novation Supernova, Ensoniq, vintage Macs and the like.
Re: Roland D50 Drifting Out Of Tune
Some time ago I got fooled by something similar. It turned out to be the pitch wheel pot was showing it age.
- meatballfulton
- Gear: Logic Pro X
Try setting the bend range to 0 on a few patches and see if they stay in tune. That will confirm whether it's the bender.
