Kawai K1 keyboard : Dead Keys
Postby mindlayer » Mon Nov 13, 2006 7:59 am
I have a Kawai K1 II that works okay, save for the dead keys. Is there a procedure for fixing them that might be available? They are not completely dead, but it takes a lot to get them to sound. I have about 4 keys on the keyboard that are doing this.
Alternately, I just picked up a K-1, and am wondering will a K1 keyboard work inside the K1 II's board.
mindlayer
Postby Analog Freak » Mon Nov 13, 2006 10:09 am
When I bought my Kawai K-1 it had a couple of dead keys too. All I had to do was open her up, take the keybaord apart, clean the contacts with alcahol and put everything back together. I dunno about the K IIs keyboard working in the K-1, I know the two synthesizers are almost identical save for the reverb on the K II. So it might, but wouldn't it be easier just the control the K-1 as a MIDI slave with the K II?
Analog Freak
Postby mindlayer » Mon Nov 13, 2006 2:29 pm
It would be easier to trigger the K1 II off the K1, but I have a small car, and I'd like to have room for my bass gear as well. 8) I think the attempt at cleaning contacts with alcohol sounds like a good start, and now that I have a keyboard that will work if that doesn't, that's probably the best choice.
I mainly use it to trigger soft synths in Sonar.
mindlayer
Dead keys--- k1
Postby coolsci » Wed Nov 22, 2006 7:14 am
My Matrix-6 was giving me the same problem. However it might not be a serious problem at all. If you are able to get those keys to sound with a midi controller then the problem is dirt in the contact points. Remove the key(s), clean out the dust and grime as much as possible with a dry cloth. Use rubbing alcohol to get the rest (do not saturate). Dry off then give em a squirt with Deoxit D5.
coolsci
Return to HELP!
Users browsing this forum: No registered users and 14 guests
