Juno 60 headphone out too quiet, main out noisy
- artfulideas
Basically, the headphone out is really quiet, and in mono, even when the hi/med/lo switch is on high, and volume maxed out, AND plugged into the stereo out.
And the main out has alot of crazy, almost musical backround noise, even when turned down. The noise changes the way its acting according to which patch its on.
Ive heard this is just how the Juno 60 is in general, but I find it hard to beleive this is standard.
Any suggestions or quick fixes?
thanks
thanks
Drum machines: Machinedrum UW mk II, modded TR-606, TR-707 & TR-727 (both circuit bent), ER-1 mkII
Synths: MFB Synth II, MicroKorg, modded Fatman, Mini theremin
- Maschinengeist
- Real name: Steph. J
- Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
That could be just a matter of adjusting the VCF / VCA trimpot. But that could be something else too. Pretty hard to say from a distance (at least in my case). Of course, an inspection with an oscilloscope can test you more.
I doubt that it's a bad cap case. Sounds to me like a filter problem.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
MuzikElektronix.com
Help? See TechZone
Parts? email!
- artfulideas
thanks, the filter is ok, and maybe Im exagerating about the noise, it snot that loud.. But another thing I didnt mention is the master volume pot is scratchy. Maybe thats the culprit?
He machiengeist, I still need you to do those retrofits and repairs we spoke about. I sold my CS-01 but am looking for a MKII as we speak. thanks. hey, maybe I willl do the ridiculous thing and send you the J60 too?
- Maschinengeist
- Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
Cool. I'll have an eye to my PMs/emails then.
Well, in VERY extreme case of dirt in the pot, that could atenuate the output. A bad cap too. But I'm still sold to the idea of the filter though.
The filter might appear to be correctly working from the control panel BUT doesn't filter out correctly (and that is more subtle to detect).
MuzikElektronix.com
Help? See TechZone
Parts? email!
MuzikElektronix.com
Help? See TechZone
Parts? email!
- Gear: tin cans and rubber bands
- Band: Me twiddling in the corner...
- artfulideas
Hmm, maybe Ill try fixing/replacing the volume pot first since that definitely needs looking into anyways...
Should I spray contact cleaner in there or is that a bad idea? Maybe I should take it apart and just clean it or something? That kind of stuff is sort of fun.
- artfulideas
thats sort of what Im doing. also a filter set to the right setting would eliminate most of the noise cus it sounds like its all super high frequency.ColorForm2113 wrote:what worked for my friend is he would keep the the pa/amp volume really low, set it to high out out and turn the volume on the synth up higher, i dunno sounds a lil weird but it worked for him
- nathanscribe
- VSE Review Contributor
- No Longer Registered
- Maschinengeist
- Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
You cannot take apart the pot. To clean it, just spray contact cleaner around the shaft and turn the post fast a few seconds. You might need to do it a few times to remove the dirt. Just go with a little amount of spray... Don't empty you can in there!artfulideas wrote:Hmm, maybe Ill try fixing/replacing the volume pot first since that definitely needs looking into anyways...
MuzikElektronix.com
Help? See TechZone
Parts? email!
MuzikElektronix.com
Help? See TechZone
Parts? email!
- Anaki_Muon
My main volume causes crackle too. I get around this by not adjusting it when I play.
I had the same problem with the main outs as well- but I found once I simply stuck a power-bar between my wall outlet and the Juno 60 it solved the problem. I think the 60 is really sensitive about the power it consumes. One should use a power-bar between everything anyhow.
Korg MS20 & Wavestation A/D, Roland Juno 60 & Juno 106 & MKS50 & D110 & MC202, Ensoniq EPS, Yamaha FB01, SP07b, Casio CZ5000 & SK1, Alesis Micron, Cakewalk Z3ta+, Propellerhead Reason, Garriton Personal Orchestra
- artfulideas
power bar? the only thing I know of by that name is a health snack.
Does it have something to do with the grounding? Since I got it Ive only have had it on a keyboard stand, should I try it on a table?
thanks
thanks
