It's been a long time since I dug into an extensive electronics project. I remember most of the basics of circuit and component testing, but there's a lot of stuff I have forgotten. I have a few questions...
Resistors:
Can a resistor be properly tested while in a circuit?
If it is tested in a circuit will it give you the correct reading?
Diodes:
Same question, can it be tested in a circuit?
What reading should you get from a good diode?
Capacitors:
What's the best way to discharge and test a capacitor?
Transistors:
What reading should you get from a good transistor?
After I get answers to these questions I'll have more....
Correctly Testing Electronics
- Tardis
- Location: Seeking out new life and new civilizations...
"When natural inclination develops into a passionate desire, one advances towards his goal in seven-league boots." ~Nikola Tesla~
- haaplaj
- Gear: Juno 60, Fantom S, TG 77, Digitakt, Wavestation SR
Well, anything that is connected to circuit, cant be that
properly tested.
I think only diodes can be tested in the board,
diode should conduct only to one direction and
usually it's usage is that on most circuits.
Use analog ohm meter on diode with low ohm reading,
or digital meter, with the diode range.
Transistors can be tested as diodes, either PNP or NPN
is an two diode circuit. FETS and MOSFETS cant be tested that way.
However, bigger transistors can have inner bypass
diodes or resistors. You should check datasheets of those by model.
If you want to check an capacitor, in most cases you have to
take it off from board to get capacity readings.
You can test capacitor overall with analog multimeter
with low ohm ratio, by connecting leads to it and then
reversing the leads from capacitor connections.
The meter needle should jump, as it first
charged it and then re-charged it.
This usually can only reveal shortcircuited or dry
electrolyte capacitor.
Do not use this on any heavy loaded big capacitors
that may still have charge.
You can safely discharge a capacitor by
short circuiting it with resistor having low
ohm reading (About 22 - 100 ohm).
properly tested.
Rhythm turns group of sounds in to music.
https://soundcloud.com/haaplaj
- nathanscribe
- VSE Review Contributor
Ah, so that's how you do it... Would this work with a cheapo digital meter too, or is the response too slow?haaplaj wrote:If you want to check an capacitor, in most cases you have to
- No Longer Registered
- haaplaj
Yes as I mentioned:
I think, analog meter is essential.
You could use a light bulp (Used in cars)
with resistor in series to see is there charge.
- Tardis
A headlight? What kind of bulb are you referring to?haaplaj wrote:I think, analog meter is essential.
- haaplaj
Sorry, I ment the headlight.
You could use an flaslight bulp also with
the resistor having more ohms.
- Anaki_Muon
In terms of the car light-bulb trick... the first project I made was a box that plugged in to a wall outlet, had a light-bulb fixture in it and had a plug on the other side. It works just like a breaker, but if I got a short in any project I plug in to the box, and the bulb is the same voltage as the project, the bulb will burn brightly, otherwise it will be dull (it's on the return circuit from the plug for the project to plug in to).
Wow. That's a garbled description. Should I rephrase that or does somebody know what I mean?
Korg MS20 & Wavestation A/D, Roland Juno 60 & Juno 106 & MKS50 & D110 & MC202, Ensoniq EPS, Yamaha FB01, SP07b, Casio CZ5000 & SK1, Alesis Micron, Cakewalk Z3ta+, Propellerhead Reason, Garriton Personal Orchestra
- Maschinengeist
- Real name: Steph. J
- Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
I'm tired and don't feel too much to write:
http://www.cirris.com/testing/guidelines/testcomps.htm
That should help you out a bit
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
MuzikElektronix.com
Help? See TechZone
Parts? email!
