will do.DX wrote:Remember that my APO relay was crazy and even sometimes my synth switched off itself. After several checks, I just cleaned the Power ON OFF switch. Try to do it, nothing to loose.Tyler2000 wrote:Well, I tested with batteries, which likely leaves one option. Busted APO. How does one go about fixing thatt? Could it be something else?
Open the keyb (take care about wires, casio CZ series are really cheap-wired) and spray with contact cleaner the switch.
Hope it helps.-
What's wrong with my CZ-101!!??
- Tyler2000
- Gear: HS-60, MG-1, CS-5, ESQ-1, CZ-101, DR-110, MR-10, MDP-40, EA-1, ER-1, ES-1, Trixer, SDS-9, Califorian 365, toys, guitars, ukes, etc.
so what do I put down here now?
- Tyler2000
Hope it helps.-
(warning. I'm a dan deacon fan too.)
I am waiting for Dan. I asked him if he could send me "OHIO" lyrics because I don't understand it much well, and still waiting....
Dan Deacon, send me the OHIO lyrics for doing a cover please!.
Let us know if the switch cleaning fix something of your problem.
Roland Promars, E-mu EMAX and some other machines...
My CZ 1000 was doing a similar thing when I first got it. I thought it was a matter of a loose power jack and that I would just have to re-flow some solder to fix it. I opened it up and that was not the case.
It turns out it was just that the center pin of the power jack was making only intermittent contact with the plug. I solved the problem by just bending the center pin of the jack downward slightly. Now it binds nicely and completes the circuit. You can try that, but careful not to bend it too far. Good luck.
Slightly OT:
Did you know that the battery cover of the CZ-101 and the CZ-1000 are interchangeable? It's true.
Slightly OT:
synths
Re: What's wrong with my CZ-101!!??
Hey Tyler2000,
just found this thread as I have the exact same problem with my CZ-101 as you had back then. Did you solve it? How?
Thanks a lot!
Banni
Thanks a lot!
Banni
Hey i have the same issue with my cz 101, total newb to synth and electronics in general but who would i take this to for repair?
I can fix it for you. I have done three CZ101s in the past week. It is almost always something simple. The way the jacks are mounted leads to a lot of cracked solder joints and as others have said the APO circuit is a nightmare. There is a lot you could probably do, even if you consider yourself a noob. Can you give me some symptoms before it quit working? Have you tried powering it from batteries and AC adapter? Is the AC adapter in good shape or does it power other gear (careful of polarity of the tip before you go plugging it into everything)?
What general quadrant of the US do you live in? There may be someone much closer than myself. Shipping can be a bear for keyboards. I am more than happy to help you poke around and diagnose things but if you just want a repair person/shop maybe one of the other users can help you out too.
Either way hope you get it going again
