my Old Poly six - does it need an internal battery ?
gizmogeeks
Post by gizmogeeks » Mon May 28, 2007 10:04 pm
hi all -
I have an old POLY six that has been in a rack in my studio for years It is time for it to go - and have just pulled it out to clean up and sell on Ebay - when I first turned it on to check it out - I could change the preselects with the selectors on the right - now it will not budge - and remain with all lights on - I cannot chag the tone - eveyhing else seems to work -of sorts
Is there an interall Battery of like on my D50 - or is this a common problem with poly six's.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... B:RTQ:UK:1
be great if someone could help
cheer
Paul
mistercooper
Post by mistercooper » Mon May 28, 2007 10:12 pm
I'm pretty sure the batteries in those things are prone to exploding. No joke. They leak c**p all over the PCB.
m-audio Radium 61, Korg Kontrol49,
Nord Modular rack, ER-1
Soundlab
CS-50
Custom built modular w/ ~30 modules
TX-216, VSS-100, PSR-470
Ableton Live, Reason, Cubase, plugs
Analog Freak
Post by Analog Freak » Mon May 28, 2007 10:29 pm
Sounds like that battery raised h**l with your KLM-367 circuit board. You are probably looking at a new IC or two and a mess of jumpering around the damaged sections of the board. I had to do it and it is not fun by any stretch of the imagination. Sadly, this problem is the #1 cause of a dead polysix being sold for next to nothing. Almost nobody wants to do the work themselves and the repair costs at a shop can equal or exceed the value of the synthesizer to begin with. If you want to try fixing it yourself, head on over to Old Crow's Synthesizer website at :http://www.oldcrows.net/~oldcrow/synth/korg/polysix/
EDIT: I noticed in the picture that your Tape Enable LED is on. Try flicking that switch off ant try changing patches again.
gizmogeeks
poly six
Post by gizmogeeks » Mon May 28, 2007 10:35 pm
thanks guys -
I will have a peek inside in the morning -
minime123
Post by minime123 » Thu May 31, 2007 6:41 pm
all p6's are way overdue for a battery change.
if not changed, battery leakage can cause serious damage that youll want to let a pro fix.
mini
VINTAGE SYNTH DEALER
- https://tonetweakers.com
mekonin
Gear: Roland SH-1000, SH-101, Juno 106, SH-201, TR-808, TR-626, MSQ-700, Korg PolySix, Yamaha DX7, RX5, Elektronika EM-25
Band: Margita je Mrtva
Post by mekonin » Tue Dec 11, 2007 1:50 am
i have a similar problem with my newly bought poly6
all four bank button leds are lit up when i turn it on, the first four of the preset buttons too...
in all of the presets there are just click written
but when i switch to manual, i can change the sound in every part except the VCO which does not respond
the battery doesn't seem to have leaked a lot, i've cut it right away
could it be that it ruined some chips on the board?
minime123
Post by minime123 » Tue Dec 11, 2007 7:41 am
whered you get this defective polysix?
its likely traces and chips were damaged. seems to always happen, even when the seller says "no leakage".
mekonin
Post by mekonin » Tue Dec 11, 2007 10:14 am
i bought it second hand for something like 100eur and i bought it as is, so i guess i can blame myself for getting in this mess :)
i just wanted one so bad
i know that traces can be repaired, but chips have to be replaced?
is it hard to find spare ones?
Europe Endless
Gear: Minimoog model D, Prophet 5 3.3, MultiTrak, Juno-60, 3xPolysix, Trident MkI & MkII, DW8000, DX7IIFD, KX88, and DIY Digisound SSM-based mono.
Post by Europe Endless » Tue Dec 11, 2007 6:32 pm
I fixed one with similar symptoms a few weeks ago. Apart from replacing the battery I wound up reparing 11 damaged traces under the chip closest to the battery, despite very little visible leakage...
minime123
Post by minime123 » Thu Dec 13, 2007 7:27 am
yup. theres usually damage even when not obvious. make sure you removed all that corrosion or it will come back.
