Fixing my Oberheim Matrix-6R
dreamist
Post by dreamist » Thu Jun 14, 2007 8:27 am
My Matrix-6R just went bad yesterday. One of its 6 voices is now not working. When the voice cycles to that faulty voice, it doesn't produce the sound, only crackles and noise.
There are no techs around this area. My option is to either dump it or try to fix it myself. Opening the case, the voice circuits contain only ICs, and I'm not sure where to start.
Another possible option is, perhaps, I just use it as a monosynth and don't bother with the faulty voice. I'm not sure if that's possible though. And, IMO, a Matrix-6R is not very good as a monosynth either.
What do you think I should do?
dreamist
Post by dreamist » Fri Jun 15, 2007 6:42 am
Upon further inspection, that faulty voice does produce sound sometimes, but with lower volume than usual, and with crackles and noises added. However, sometimes in a few seconds the unit is powered up, it works perfectly, then starts crackling.
I wonder if this is due to faulty CEM3396 chip? In that case, I could just find a spare one and replace it?
