DX7IIfd won't do anything
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Fri Jun 22, 2007 5:29 pm
Hi evildragon
I don't have any motherboard in stock. I rarely keep those parts (but will someday. Another work in progress). But I'll check around and will contact my part suppliers to see if one got one available.
As for test, you can persorm a few on the ICs with a digital multimeter to make sure its in/out (among other things) are accurate. It's important to follow the pinout, otherwise you'll fry the chip. Please refer to the IC Block Diagram in the Service Manual.
You can also get yourself a basic logic probe off eBay for less than $20.
Note: the previous message was intended to dachsis. Sorry for the confusion.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
evildragon
Post by evildragon » Fri Jun 22, 2007 5:31 pm
ok, i'll give those tests a shot then with my multimeter when the problems creeps up again... (continuity test, correct?)
i'm also going to find an in-circuit cap tester too..
dachsis
Gear: AllDXseries mach,60jan08),QS w/piano,(2) SY77, SY88, CS2x, PSR 6300, PSR2700,PSR550, YGP525,55c,(2) TX816, TX416,(2)TG500, Alesis1600 Mxr,QvbIV, etc
DX7IIFD won't do anything
Post by dachsis » Fri Jun 22, 2007 6:27 pm
evildragon wrote:ok, i'll give those tests a shot then with my multimeter when the problems creeps up again... (continuity test, correct?)
on IC s you are ckg the in/out values, right ?
thanks for the serv contact, these are invaluable.
No more old Yamaha serv shoppes to buyout and reap bounties.
evildragon
Post by evildragon » Fri Jun 22, 2007 6:54 pm
http://blackevilweredragon.spymac.com/dx72.jpg
http://blackevilweredragon.spymac.com/dx73.jpg
one of the IC block diagrams.. im actually curious which in and out too... i've never messed with logic gates before (i've wanted to learn)
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Fri Jun 22, 2007 9:17 pm
VCC = Supplied Voltage = Positive
VSS = Supplied Voltage = Negative
After that, it's only a matter to follow the schematics, indicating the in and the out of the pins.
More than a continuity test, it's a (basic but efficient) way to narrow down what part of the chip is bugging down.
PLEASE RESPECT THE POLARITY AND PAY EXTREME ATTENTION TO THE PIN CONFIGURATION OR YOU'LL FRY THE CHIP AND QUITE PROPABLE DAMAGE THE SYNTH IN AN UNPLEASANT WAY.
Good luck!
MuzikElektronix.com
Help? See TechZone
Parts? email!
