303 din sync to drumstation how
prince fan 2
Post by prince fan 2 » Sun Jun 17, 2007 5:44 pm
hi again..just got hold of the novation drumstation and would like to know how i
get it to sync with my 303....no manual unfortunately...
how does it sorta work..can i get away with using a normal midi cable
for connection...very new at this connection sort of lark....simple explinations please..
thanks again..
baschyn
Gear: EIII, EII, P5 rev2, Prophet VS,VP-330, OB-8, TR808,606, MPC 3000. PolyEvolver.
Post by baschyn » Sun Jun 17, 2007 5:51 pm
yes.
nathanscribe
Post by nathanscribe » Sun Jun 17, 2007 6:46 pm
You can use normal MIDI cables for DIN sync, but only if they're the type that use all the pins: Sync24 and MIDI use different pins, and not all MIDI leads are made with 5 pins soldered. If you have no luck with your particular MIDI leads, try 5-pin DIN audio cables, they're suitable.
Computer Controlled
No Longer Registered
Post by Computer Controlled » Mon Jun 18, 2007 2:09 am
Well, assuming you're in the US, go to Radio Shack. They carry proper DIN cables. BUT, if they don't have any, those colored MIDI cables you buy in 3 packs work as well. Also, i think HOSA MIDI cables work, and some of the kind with chrome heads work. Just plug the cable into the DIN socket in back of the DS, and into the 303. You're set.
prince fan 2
Post by prince fan 2 » Mon Jun 18, 2007 7:49 am
is that it no programming.no special set up.no dials to spin or press.it just automatically
syncs with the unit....
if it does ill be ammazed...
prince fan 2
Post by prince fan 2 » Mon Jun 18, 2007 7:50 am
prince fan 2
Computer Controlled
Post by Computer Controlled » Mon Jun 18, 2007 9:07 am
That's exactly what it does. Instant conversion.
prince fan 2
Post by prince fan 2 » Mon Jun 18, 2007 11:04 am
yeup got away with it....its fricking great...instant acid...
put the midi cable in the back and it all went quiet...hummm..
went to cubase on atari messed around a bit with midi implimentation nothing happened..humm
dont know what i done but....
then closed the screen and there it was syncing it time with the track...
small step for man...giant leap for prince fan...cheers buddies..
Altitude
Post by Altitude » Mon Jun 18, 2007 11:53 am
Um, you do realize of course that there is no sequencer to sync with in the drum station right? All it will do is take a midi clock signal and convert it to DINSYNC so you can slave the 303 to another midi sequencer. Makes sure the sequencer is sending clock to the drum station and it should work as long as the 303 is in sync mode (the start/stop should not work)
Computer Controlled
Post by Computer Controlled » Mon Jun 18, 2007 7:36 pm
Right, your sequencer must be transmitting MIDI Clock for it to work. Some sequencers do it automatically, some don't.
