Obx-a gone wrong...panic sets in..
Postby mavertron » Sun Jun 17, 2007 7:25 pm
Hi there,
I have just turned my obx-a on, and its lost all my sounds bar a few that sit in the #1 position.
Any ideas what could have caused this ?
should i worry ?
thanks,
matt.
I shouldnt be here. I should be writing music.
mavertron
Postby Bitexion » Sun Jun 17, 2007 8:03 pm
My instant thought is that the battery is dead. A synth's memory is a little bit of RAM (Random Access Memory, same kind we have in our computers).
It is a type of memory that is wiped every time power disappears, which is why for instance computer virii cannot survive in a computers RAM. To overcome this, a battery is attached to keep the RAM powered up as long as the synth is turned off.
If battery fails, all programs are wiped every single time you switch it off.
It has to be RAM, or you wouldn't be able to overwrite it once you wrote something in there, and that's kind of useless.
Google for "Ob-xa battery replacement" or similar, maybe you'll find a detailed guide somewhere.
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Postby dougt » Sun Jun 17, 2007 8:04 pm
The internal battery probably went dead. It uses a 3V Lithium size 2/3A.
dougt
No Longer Registered
Postby mavertron » Sun Jun 17, 2007 9:23 pm
thanks guys, it works fine in manual mode, so i reckon this must be it.
I'm going to install the encore midi kit, which gets rid of the need for the battery, so when thats done, i wont lose all my patches, cos i just have..most annoying.. :cry:
thanks,
matt.
mavertron
Postby dougt » Mon Jun 18, 2007 10:09 am
Last I heard the Xa Encore kit still wan't finished...
dougt
Postby Cybercardinal » Mon Jun 18, 2007 11:32 am
dougt wrote:Last I heard the Xa Encore kit still wan't finished...
It's finished allright:
http://www.encoreelectronics.com/cont_obxamk.html
And mine is on it's way in the post. Can't wait! Yipii...going to be great to get the monster midified
Cybercardinal
Re: Obx-a gone wrong...panic sets in..
Postby gilwe » Mon Jun 18, 2007 7:53 pm
mavertron wrote:I have just turned my obx-a on, and its lost all my sounds bar a few that sit in the #1 position.
If you're into electronic repairs, go and replace the tantalum capacitor at the battery circuit
(actually, you should replace ALL tantalum capacitors, they all going to short out soon).
gilwe
replacing caps
Postby mavertron » Mon Jun 18, 2007 9:28 pm
Hi there gilwe,
could you explain a bit more ?
Ill be sending it to my tech to add the midi kit, so maybe i could get him to do this at the same time.
If i dont do it, and they the tantalum caps die, could it harm the synth ?
thanks,
matt.
mavertron
Postby gilwe » Mon Jun 18, 2007 10:25 pm
They will.
I just restored a dead OBXa. They used a few tantalum caps at various positions, most of them went dead and caused different types of problems. The problem with tantalum caps is that they SHORT, i.e, when they go dead, they will act like a jumper !
So my advice - most important is to replace them all at once. Mine had six. Not a big deal.
But I saw ones who use tantalums at the power supply section as well !! :roll:
Your tech will know what I'm talking about ;)
Also, I heard advice saying the diode bridges at the power supply section should better be replaced with ones of higher volatge/wattage such as W04. I did that as well as replacing all caps at the PS section.
This is a killer machine and should be treated well !
gilwe
Postby gilwe » Mon Jun 18, 2007 10:28 pm
oh, and I would replace the diode and capacitor right near the battery tantalum cap as well (they are all placed near the battery)
gilwe
Postby mavertron » Tue Jun 19, 2007 7:56 pm
thanks gilwe,
i will show my tech this thread..
cheers,
matt.
mavertron
Return to HELP!
Users browsing this forum: thebotchedjob and 10 guests
