Resetting Micron with normal patches
So I downloaded a bunch of Ion sound banks and turns out I already had alot of the sounds, and now my patches are all over the place, mostly in the "Comp" category. Is there anyway where I can just wipe the system or reset it to just default patches? Or will I have to delete them 1 by 1?
- Zamise
- Gear: Rollhand P00
- Band: Quantum-Source
Maybe do an OS update on it. If you don't know how, do a search on VSE, I know I've told how in the past on here and seen someone needing help recently to do it too, it can be a little tricky. Not sure if a factory reset would reset everything like the OS update does, works pretty smooth when it works right, or maybe factory reset would do the trick too but I can't remember if there is one for the Micron and its just called updateing your OS.
Zam
Zam
- Maschinengeist
- Real name: Steph. J
- Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
If you go to Alesis website, there are support documents on how to reset the micron to factory.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
MuzikElektronix.com
Help? See TechZone
Parts? email!
