Assinging the mod-wheel of an Korg MS-10
sepiakeys
Gear: Hardware Synthesizers and Guitar Effects
Band: There will be Lions
Post by sepiakeys » Tue Aug 21, 2007 11:07 pm
I borrowed Korg MS-10 from a friend to play around with it.
Patching the mod-wheel to control PWM and Cutoff worked fine. But I could not find out how you have to patch the cable to make it control the LFO (resp. Modulation Generator).
Can anyone help me out?
Thanks!
Good programming is worth more than the most expensive synthesizer.
audible
Post by audible » Wed Aug 22, 2007 12:21 am
You simply can't do that. The LFO shape, frequency and amount can't be controlled via the patch panel, just from the pots. There are only two outs, no ins, for LFO.
"The concern of the musician is music. The concern of the professional musician is business. Only become a professional musician if there is no choice." Robert Fripp.
sepiakeys
Post by sepiakeys » Thu Aug 23, 2007 12:20 pm
So there is no way to use the mod-wheel for vibrato (which is very common for mono lead-sounds)?
audible
Post by audible » Thu Aug 23, 2007 4:13 pm
Without external gear or modifying the MS-10, no.
