The rare and elusive Akai Z4 and Z8 service manual and schematics:
http://www.mediafire.com/file/lduhp0tbm ... l.pdf/file
Sorkin Multivox MX3000 Owners Manual (with schematics):
https://mega.nz/file/sZlzFLRI#VktgG5ot1 ... a8eaHfRKbQ
Kawai R50/R50e Service Manual (with schematics):
https://mega.nz/file/wA0h3SaR#dYLOJD_1P ... Gf0SghJL6w
Service Manuals and Schematics!
- Gear: ESi32/E6400U, Novation Supernova, Ensoniq, vintage Macs and the like.
Emu E4K
Anyone know if there is a schematic for the Emu E4K. Mine has a warm up issue with the keyboard part, 8 keys don't work but come into life about 20 mins later and then work perfectly. My guess is a bit/line on the keybed contact scanner chip is failing. It would help to know if it's a replaceable chip or some custom device. The former I can replace. A schematic would help me locate the culprit much faster.
- Yekuku
Re: Service Manuals and Schematics!
Hi blueknob, I have uploaded it here :
https://www.sendspace.com/file/8648nc
You can use a hairdryer and a freeze spray to find the culprit.
It is all about sharing...
Thanks Mr Y - that's very good of you and sooo fast!
Had a quick look.. hmm.. once big chip does it all, more.. hmm..
at least I now know where to look.
thanks again
thanks again
- Yekuku
You are welcome blueknob!
A few ideas :
1) check/clean/reattach the fatar keyboard connectors. Replace cable if possible.
2) 8 keys mean that 1 bus has the problem. Could it be due to a leaky diode ? Replace diode on the specific bus.
3) The scanner ic looks like a custom EMU ic, thats bad news.
A few ideas :
I studied the circuit, got to the K-Chip emu use for keyboard scanning, worked out exactly which bus line (pair - make and break) - took close look for that specific connector and noticed it was slightly skewed (not in 100% on one end) - pushed it in 1mm. So far all working now
result.
I'm looking for the Schematic s for the Jen SM2007.
If anyone still has them could I obtain a copy please.
Many Thankx in advance.
G.M
G.M
