Any sort of workaround with synths without midi thru?
Alex E
Gear: Jupiter-6, Juno-60, Polysix, Emulator II, DX7, QX1, Arp Odyssey MKII, ESQ-1, Miami, M1r, Live 9, iMac MC309XX/A
Post by Alex E » Thu Nov 08, 2007 3:06 am
My ESQ-1 and TR-505 both lack Midi thru, and so will the more modern JP-8000 when I get one (wtf, right? :evil:) So is there a way to work around this? Like a little box I can put on the synth/drummachine in question and hook up my midi cables a certain way? I daisy chain my synths together and sequence them with my mmt8 so I can't work with more than 2 peices of gear w/o midi thru.
soundcloud.com/vectron
micahjonhughes
Post by micahjonhughes » Thu Nov 08, 2007 3:18 am
You want a midi patchbay. There are lots of different ones out there left over from the 80s.
Alex E
Post by Alex E » Thu Nov 08, 2007 3:35 am
thanks
Z
Post by Z » Thu Nov 08, 2007 4:52 am
MJH is on the right track, but patchbays really shine with complex MIDI rigs with multiple controllers, sequencers an such. Patchbays have multiple MIDI INs & OUTs (8x8 is a typical configuration) and allow you to route the signal from the different INs & OUTs. Some models allow merging of mutliple INs, filtering of certain MIDI data, and other features.
A simple and inexpensive solution is a MIDI THRU BOX. These have one MIDI in and several OUTs. These boxes are usually the size of small drum machines, but some are rack mounts. I have a Roland A-110 which is a rack mount thru box which also has a 88 key display that lights up when note data is present. Thru Boxes usually sell on eBay from $5 - $20 whereas patchbays are $75 and up.
Good luck!
Z
burnt toast
Post by burnt toast » Thu Nov 08, 2007 2:25 pm
ive got a motu midi express from the early 90's that merges 4 midi ins to 6 midi outs... it was about £20.
pricklyrobot
Post by pricklyrobot » Thu Nov 08, 2007 8:22 pm
Casio TB-1 is another good Thru box (2 ins, 8 outs), not too big (I'm gonna guess maybe 12"x 4"), and it can run on 6 AA batteries (it doesn't use much power so they'll last forever) if you're short on outlets.
Alex E
Post by Alex E » Thu Nov 08, 2007 8:47 pm
I'll probably get a midi thru box to save space and $$. Thanks for the extra info guys.
Altitude
Post by Altitude » Thu Nov 08, 2007 9:33 pm
IIRC the 8000 has a soft midi thru, you should only need to turn it on
tunedLow
Gear: Sage XP 4wt 10
Sage TXL 3wt 710
Post by tunedLow » Fri Nov 09, 2007 9:50 am
Nice to see someone else with a TB-1! The thing is a champ.
xpander
Post by xpander » Fri Nov 09, 2007 10:29 am
can't go wrong with the USB version of the motu midi timepiece AV, it- along with the 896 and 828- are the heart of my studio. using the MIDI THRU on any synth is a happily forgotten memory, although it always seems wasteful tying up a precious MTP port with a 1-part-multimode synth; however, simple midi routers / midi patchbays really seem like a product of yesteryear.
Altitude
Post by Altitude » Fri Nov 09, 2007 2:36 pm
Follow up: I confirmed this, its on page 97 of the manual. There is a soft thru (meaning everything coming into the in is echoed to the out). So you can connect the midi out of the 505 to the midi in of the 8000 and the 8000 midi out to the ESQ-1, no additional hardware needed to send sync.
pricklyrobot
Post by pricklyrobot » Fri Nov 09, 2007 3:58 pm
xpander wrote:can't go wrong with the USB version of the motu midi timepiece AV, it- along with the 896 and 828- are the heart of my studio. using the MIDI THRU on any synth is a happily forgotten memory, although it always seems wasteful tying up a precious MTP port with a 1-part-multimode synth; however, simple midi routers / midi patchbays really seem like a product of yesteryear.
Yeah, why buy a simple $30 piece of used gear that solves your problem when you can drop $500 on something state of the art that does a bunch of things you don't need? Makes perfect sense.
pricklyrobot
Post by pricklyrobot » Fri Nov 09, 2007 6:14 pm
tunedLow wrote:Nice to see someone else with a TB-1! The thing is a champ.
I just upgraded to a Digital Music Corp MX-8 (also worth a look, they go for $50-$75 these days) because I needed some MIDI filtering capabilities, but I think I'll hang on to the TB-1. It doesn't take up too much space and I may need it later if my set-up keeps getting bigger and more confusing. :wink:
xpander
Post by xpander » Fri Nov 09, 2007 7:27 pm
pricklyrobot wrote:
... why buy a simple $30 piece of used gear that solves your problem when you can drop $500 on something state of the art that does a bunch of things you don't need? Makes perfect sense.
basically, i see a list of synths in the signature line and advise it's time to take the plunge. i bought my MTP used for less than $250, the Express XT is commonly sold less than $200 so the bite isn't so bad.
