Moog Rogue CV problems
Meso
Gear: Roland MV-8800, DSI MEK, Novation KS-4, Waldorf µwave XT, FutureRetro Revolution
Post by Meso » Mon Nov 26, 2007 2:21 pm
Hi
I am having some problems sequencing my Rogue through CV,
I am using a FR Revolution as a sequencer and midi->cv converter
and when i play a note on the rogue through CV it doesn't play the correct note, but when i disconnect the CV jack and play it via its own keyboard it plays correctly,
am I missing something here, both use the volt/oct standard, right?
Bross
Post by Bross » Mon Nov 26, 2007 6:52 pm
Go through the Rogue calibration procedure and make sure the Rogue CV out is 0V for low F and 2.58V for high C.
I haven't used an FR Revolution but it may be putting out 0V for midi C0 instead of an F. The manual online doesn't specify. A volts/oct standard only indicated that the scale matches, e.g. an octave on the Revolution is an octave on the Rogue. It won't necessarily mean F=F. You probably need to do some transposing on your controller, Revolution, or Rogue.
By the way, looking at the Revolution manual I don't think you can use that gate signal with the Rogue because the Rogue uses an S-Trigger gate.
Meso
Post by Meso » Mon Nov 26, 2007 7:03 pm
Thanks for the reply Bross
I will check out the service manual about calibration,
and regarding the s-trig it worked fine together other than the pitch was not correct,
although I had to have the trig jack half way in on the rogue to work correctly.
Bross
Post by Bross » Mon Nov 26, 2007 8:40 pm
I forgot the Rogue has V-trig on the gate jack also.
