basic (aka stupid) question about oscillator sync
ianjhicks
Gear: 808, 707, pro one, juno 60, jx3p, juno 106
Band: Soft Metals
Post by ianjhicks » Fri Dec 28, 2007 5:17 am
Can someone explain to me the difference between hard and soft sync?
danks
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Fri Dec 28, 2007 5:48 am
I could be wrong, but I think this is the difference:
In hard sync the slave oscillator is set to restart when the master finishes its cycle.
In soft sync the slave oscillator's waveform is inverted when the master finishes its cycle.
Dirk
Post by Dirk » Fri Dec 28, 2007 6:08 am
OriginalJambo wrote:I could be wrong, but I think this is the difference:
Exactly right.
The result is that with hardsync the synced ocsillator alway's has the same root frequency as the master oscillator. With softsync the synced oscillator will alway's be a harmonic of the root frequency of the master oscillator, and that frequency can also be a subharmonic of the root of the master oscillator.
All Animals Are Created Equal But Some Are More Equal Than Others.
V301H
Band: The Characters
Post by V301H » Fri Dec 28, 2007 7:17 am
I remember when I first discovered the hard-sync on my Odyssey back in 1973. I was so amazed at the almost human voice-like sound it produced. The next time I heard that sound is when the Cars came out with "Let's Go" a few years later.
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Fri Dec 28, 2007 6:35 pm
Here's heavy theory on the subject of soft and hard sync:
http://www.clavia.se/nordmodular/Modula ... story.html
No analog oscillator ever came with a softsync input. Only hardsync. Soft sync must be created using other tricks.
You can generally say that soft sync sounds less rough than the sharp, raspy hard sync. But they are really two very different concepts.
esqoner
Post by esqoner » Fri Dec 28, 2007 7:00 pm
that is not a stupid question.
don't bash yourself!!
ianjhicks
Band: Soft Metals
Post by ianjhicks » Fri Dec 28, 2007 7:57 pm
thanks for the link bitexion, interesting read!
Huppo
Gear: V-synth, broken Fusion 6HD, HPD10, MP-7, 60+ guitars, etc.
Band: naught
Post by Huppo » Fri Dec 28, 2007 8:49 pm
esqoner wrote:that is not a stupid question.
Seriously! I just learned something new. Thanks for asking the question.
~huppo
Please feel free to add me to your Foes list.
Dirk
Post by Dirk » Sat Dec 29, 2007 12:02 am
Bitexion wrote:Here's heavy theory on the subject of soft and hard sync:
I don't think you have completely understood the article you posted.
My System 100 has both hard and softsync and my A6 to, both are analog synths. It depends on the type of vco used, only 1 type can do softsync and both types can do hardsync.
See the quote from Rob Hordijk's article:
The other type of oscillator mentioned, the one that generates square-triangle waveforms at the same time also uses a capacitor, but this capacitor is not shunted. After the charging reaches a maximum level the charging current is reversed and the capacitor is discharged in the same rate as that it is charged, resulting in the triangle waveform. The charge/discharge signal results in the square waveform. Now we have two possibilities. We can still shunt the capacitor with an extra shuntcircuit, enabling hardsync. But we can also force the oscillator to toggle the charge/discharge state. This forces the triangle waveform to reverse it’s direction. This is called ‘soft’-sync and sounds distincly different from hard-sync. E.g. hardsync can generate a strong transient in a synced trianglewave on the syncing moment, but softsync will by itself not add such a strong transient. So it sounds smoother.
carbon111
Band: Carbon111
Post by carbon111 » Sat Dec 29, 2007 12:53 am
Bitexion wrote:No analog oscillator ever came with a softsync input. Only hardsync.
The oscillators on the Serge Modular do softsync only.
(Hardsync-type sounds must be achieved via Wave Multipliers or DSG syncing.)
Best Regards, James
My New album "Persephone":
Post by meatballfulton » Sat Dec 29, 2007 1:01 am
Bitexion wrote:No analog oscillator ever came with a softsync input. Only hardsync. Soft sync must be created using other tricks.
PAiA's 9720 VCO has soft sync but not hard sync. I'm not sure how it's implemented.
Dirk
Post by Dirk » Sat Dec 29, 2007 9:21 am
It's an eazy mod to hardsync them. Read the quote from my previous post.
meatballfulton wrote: PAiA's 9720 VCO has soft sync but not hard sync. I'm not sure how it's implemented.
Again read the quote from my previous post.
insky
Post by insky » Sat Dec 29, 2007 10:12 am
The JX-8P has both soft and hard syncing...I'm not exactly sure how Roland did it but it's still (semi) analog.
Stuff I own:
X Station
ESQ-1
JX-8P
Poly 800
MaxiKorg 800DV
Elka Rhapsody 610
Dirk
Post by Dirk » Sat Dec 29, 2007 4:08 pm
insky wrote:I'm not exactly sure how Roland did it but it's still (semi) analog.
See previous post.
:mumum:
insky
Post by insky » Sun Dec 30, 2007 1:14 am
See previous post.
:mumum:
Yeah, somehow I completly missed it when I was reading this. I saw it after I posted though. :oops:
Stuff I own:
X Station
ESQ-1
JX-8P
Poly 800
MaxiKorg 800DV
Elka Rhapsody 610
