Microkorg?
kylejun06
Microkorg?
Post by kylejun06 » Mon Dec 31, 2007 4:53 am
Can someone please explain to me how I can make more complex sounds on a microkorg? I've only gone so far as to edit the oscillators and add effects on a blank program. I don't know how to work the LFO filters and such. :/
Shleed
Real name: Ashley Dolan
Gear: Doepfer A100
MFB Synth II
Korg MS20 Mini
Ensoniq EPS-16+
TT303
TX81Z
Band: Shledge
Post by Shleed » Mon Dec 31, 2007 11:18 am
Eh, read the manual?
Yeah, that will do.
kylejun06
Post by kylejun06 » Mon Dec 31, 2007 1:19 pm
Shleed wrote:Eh, read the manual?
Yeah, that will do.
oh i have. trust me hahaa. yet as the total n00b that i am, i have no idea what they're talking about. does anyone know anything i could read or watch that could help me with this? hmm?
kk994
Post by kk994 » Mon Dec 31, 2007 1:55 pm
There's a free book on the ARP 2600 and subtractive synthesis generally at
http://www.samecoff.com/works.html - each chapter has about 10 questions after it making sure you're keeping up. Also there is a CD with 99 samples highlighting certain techniques in the book. Well worth the download.
The MicroKorg is different but the techniques are the same. You can also download a free version of the Arp 2600 from http://glenstegner.com/softsynths.html.
tallowwaters
Gear: LC-MS/MS
Post by tallowwaters » Mon Dec 31, 2007 4:56 pm
1 use layered patches
2 use the modulation matrix
3 go to arp settings, select 'trg' as the pattern, note length to 100, and in the other arp section set the gate to on (so it sounds constantly with no fingers on the kybd)
4 now start playing around in the mod matrix
5 when setting things to lfos make on lfo fast and the other slow
6 use the built in effects
shaft9000
Real name: Dave
Band: moneymoneymoney
Post by shaft9000 » Mon Dec 31, 2007 6:32 pm
since it's bi-timbral you can layer/split/pan two sounds per patch to make it sound much more expansive and complex.
if you really want to move well beyond the presets the mK is far from ideal - you're much better off w/ a ms2000 for this
