Help with synching some classic Roland gear.....
I sold my Juno 60 a while back and have been playing with soft synths ever since. However, my analogue withdrawal symptoms are really getting to me and I'm thinking of making some purchases......
Basically, I'd like to get set up with a SH101, a Juno 106 and a TR606. I'd mainly be doing live stuff with them.
My question is, how would I synch all these machines together? Would I be able to sequence them all?
I'm also thinking of getting a phrase sampler such as the SP808. Again, would this fit in and synch with this set up?
Thanks!
Thanks!
- hollandturbine
I have to agree with Mirt.
The Juno 106 has MIDI so will work with a modern set up.
The non MIDI machines will talk to each other no problem, but you really want to use MIDI.
DIN sync to MIDI is what you will want for the TR 606 to keep tempo with your MIDI gear, and MIDI to CV is what you want for the SH 101, you could make do without the MIDI to CV and just use MIDI to DIN sync if you want to use the TR 606 to sequence the SH 101, but it is limited and very time consuming to program and might not be ideal for a live set up.
you might want to download the manuals for each machine to see what the sync options are.
The 606 has trigger outputs which can step the 101's arpeggiator or sequencer, but there is no way to hook the 106 up to those others without a converter of some kind. I'd suggest getting a simple MIDI sequencer, such as an Alesis MMT8, and a TR707 rather than a 606, because it has MIDI sync, and still retains a trigger output which can be used for the 101. Plus, a 707 still runs a bit cheaper on eBay and such places than a 606.
- Tyler2000
- Gear: HS-60, MG-1, CS-5, ESQ-1, CZ-101, DR-110, MR-10, MDP-40, EA-1, ER-1, ES-1, Trixer, SDS-9, Califorian 365, toys, guitars, ukes, etc.
why not just go back to the j60? Other than (more) patch memory and midi the j-60 is a better buy. Since midi is the problem and those synths are so simple that patch memory is sort of silly, wouldn't this be the best solution.
Then you could trigger the arpeggiator via clock signals from the 606 (right?).
Oh wait, I guess you were wanting to run sequences on the juno, so what would you be using as your sequencer for the juno? Maybe if you get one that has the right connections that could be your ticket...?
so what do I put down here now?
- King Julien
I've got the 101 and 606 and they work really nicely together via trigger out to clock in. Much easier to use the 606 to sequence the 101 like this vs using the 101's sequencer.
However, I now also have added a FR revo. has din sync to the 606. So far so good. however, today I realised that the 606 will not trigger the 101 when is is receiving Din sync fro the revo. Very disappointing. I'll be trying the cv/gate but it won't be the same.
- nathanscribe
- VSE Review Contributor
It shouldn't be a problem. How have you got things set up? The DIN Sync input on the 606 drives the clock, not the triggers. The triggers are only fired by the toms. I run my 606 from a MIDI-DIN Sync convertor and use the toms to trigger Juno arpeggitors, and never had any issues with what you're describing. Double check your patterns and connections, I think.King Julien wrote: today I realised that the 606 will not trigger the 101 when is is receiving Din sync fro the revo. Very disappointing.
- OriginalJambo
- Gear: Check my sig
- King Julien
Thanks, I'll try again and report back.nathanscribe wrote:It shouldn't be a problem. How have you got things set up? The DIN Sync input on the 606 drives the clock, not the triggers. The triggers are only fired by the toms. I run my 606 from a MIDI-DIN Sync convertor and use the toms to trigger Juno arpeggitors, and never had any issues with what you're describing. Double check your patterns and connections, I think.King Julien wrote: today I realised that the 606 will not trigger the 101 when is is receiving Din sync fro the revo. Very disappointing.
- xpander
- Gear: UltraProteus, Xpander, 200e, Minimoogs, Radias, Prophet VS, PolyEvolver, Arp 2600
a Kenton Pro-Solo mk2 is $150 less (going by bigcitymusic.com prices).Altitude wrote:Except for the fact that it costs 150$ more than a mobuis and does less...OriginalJambo wrote:A Kenton Pro 2 can be had for a rather modest sum, and that will allow you not only to sync your Roland sequencer/arps but also sequence two synths independently via MIDI.
- King Julien
OK it works now - not sure what I was doing wrong.King Julien wrote:Thanks, I'll try again and report back.nathanscribe wrote:It shouldn't be a problem. How have you got things set up? The DIN Sync input on the 606 drives the clock, not the triggers. The triggers are only fired by the toms. I run my 606 from a MIDI-DIN Sync convertor and use the toms to trigger Juno arpeggitors, and never had any issues with what you're describing. Double check your patterns and connections, I think.King Julien wrote: today I realised that the 606 will not trigger the 101 when is is receiving Din sync fro the revo. Very disappointing.
